Utorch H09
Rechargeable Headlight
The Utorch LED headlight flashlight, using Cree XPL - V6 LED bead, with 1000 lumens maximum output, 8 modes for all lighting needs, and a maximum beam distance of 200 meters, is a necessity for outdoor activities, like hiking, camping, travel, home use, gifts and emergency lighting.
Main features:
• Super bright CREE XPL - V6 LED, max 1000 LED lumens output and max 200m beam distance
• 4 brightness levels, suitable for different environments
• Rugged indestructible aluminum body with anti-scratching type III hard anodization
• Built-in magnetic charging system, fast charge and convenient
•Multi-level dissipating heat design and new copper starboard, excellent heat dissipation.
•Side switch button to change modes and adjust output, one-handed control
• High-efficiency driver circuit, no visible flash in any mode
• Automatic memory function, remember last used setting
• New intelligent temperature control technology for headlamp stable and safe use
• Reverse polarity protection to protect from improper battery installation
•Low-voltage prompts function, the light will flash when the battery is low
• Lockout function to avoid light turn on by unexpected
•Waterproof IPX8, suitable for rainy weathers
• Power supply: 1 x 18650 ( not included )
My threads:
GearBEST.com Coupon Codes&Flashsales
