The actual candela seems to be a (little
) short of the stated factory number. I think we all knew that would be the case, but the difference is rather dramatic.
Not surprised given the reflector size
Shame on Astrolux for their false advertisement ![]()
Well at least we now know the conversion rate.
1 Candela = 5.3 Chandela.
Truth revealed ![]()
Thank you for the effort.
It seems to suffer from imperfect led height too. At least mine has a clearly visible donut hole.
Not sure if new ref design would be necessary. Iβve had Wurkkos T30s and Convoy L21B both with SBT90.2 and both had a slight donut hole. However it appears to be visible only when illuminating at close distance.
It is quite interesting because astrolux was most of the time close with their numbers in their products and this is extreme difference. I wanted to buy this light but was waiting, now I have bought FT02S from them that has real numbers ![]()
The fact that they had prior experience with the MF05 makes it seem even more bizarre.
Maybe someone forgot to calibrate their abacus.
No surprise here. Those numbers are absolutely impossible with those dimensions.
I guess thatβs no surprise. Those specs seem way off. The reality seems pretty close to what you would expect from any other single SBT 90.2 light.
