Hi all,
New to this forum and new to high power torches in general.
I came to LED torches through my main hobby, shooting.
I had a Maglite for years until someone showed me a surefire aviator. I couldn’t believe a light that small could be that powerful but hated the fact that it needed CR123 batteries.
I bought a Maglite Led replacement bulb in the US about 6 years ago and have been using that as my main hunting torch ever since. Compared to the standard 2D bulb the thing was a revelation and extended the battery life immensely to boot.
I stumbled across one of these on special offer at Robert Dyas over here in the UK for a measly 6 quid: http://www.merchandisemania.co.uk/promotional-product/torches/3096/3w-cree-head-torch.html and was again blown away comparing it to my modified Maglite.
The problem with this torch is that the battery life is not much good on 3 AAAs and that they tend to die after a few months.
I was researching a better headtorch and found this site, unfortunately only after buying one of these: http://www.maplin.co.uk/p/refrakta-1000-lumen-rechargeable-bike-light-a15ln for 40 quid at Maplins only to discover you can get them from ebay for ~20 quid…
This torch puts out a lot more light, I can use it to light my bedroom up at night on high by pointing it at the ceiling, but has a few issues also.
The spot is less intense than the spot projected by the cheapo 3AAA torch above, although much larger, and it generally doesn’t seem to throw as far as I’d hoped. Also the battery supplied is a pack of 4 li-ion cells in parallel with a long ( 1m plus) wire to the light itself. I remember enough electronics from school to know that at 4 volts the resistive loss over a metre of wire would be considerable, I wonder if this is holding the light back?
My needs in a head torch are slightly complex, I need both flood, throw and something in the middle. A light for shooting needs to have good throwing capability for situations like looking for shot game in stubble fields at night. Especially when using nightvison sights estimates of range and position can look very different udner visible light and I need the ability to cast a decent beam out to about 150 yards or so. I also need flood lighting for things like climbing into high seats, gutting game after dark and sorting my kit out. In these circumstances the 1000 lumen light on high has enough spill but so much light in the spot that I can’t actually see what I’m doing directly under the spot. Considering that I will necessarily be dealing with a gun or knife in my hands in this scenario, it’s important… ![]()
The wide/spot combo is useful when looking for things in very thick cover. In these circumstances a pure flood light doesn’t reach out far enough and a spot doesn’t cover enough ground and causes over-intense spots as with the example above.
The soloution seems to be to combine the best of the two designs, ie. a more powerful and better built version of the 3AAA headtorch.
Does anyone do anything like that or do I need to build my own?
I have basic electronics ( Did an A level many moons ago) and reasonable fabrication skills ( Model engineering) with acess to a machine shop for reference.
With thanks,
Cuddly.
