I have a S2 with OP reflector, and tried the smooth one.
Not throwier, but the beam was not very nice…IMO keep the OP one.
With a XP-G2 it could be more throwy, my brass beauty was throwier with a XP-G2 than my S2 with XML2 (even with the shorter reflector)
BUT I have another suggestion :
Why not try a 10° TIR optic in your S2+ ?
Even with an XML2 I think that it could be good.
Try a Dedomed Xp-G2 in the older S2 (shorter brass pill /deeper reflector) I’ve built several with smooth reflector with a perfect beam and 35klux in throw
TIR not only focuses the beam the way you want it (60° for me because I want flood), it also blends all the ooky Cree color rings into a smooth “white” color.
Plus (at least with mine), I can slightly modify the tint color OTF by using a permanent marker to color the outside of the TIR. I did that to stop lumens from escaping the “back” of the TIR, and found the black Sharpie coating skewed the 3C XM-L’s tint too “blue”. If I tried that again I’d use White ink if such a thing even exists, or the Silver used to mark dark objects…
My complaint with the S2+ was that it was just to floody. I talked with Simon and he suggested a TIR, and told me which one, so I tried it. I will not go back to a reflector in a tube light again! I now has a wonderful hotish spot that just falls off to nothing. The throw was definitely increased and maybe a tiny amount of light is lost. I used a permanent silver glitter pin on the back side of the TIR and the tint is wonderful! The light is built with a 6*7135 (.380 mah) driver and an XP-L2 in 3C.
thanks for the suggestions
I will try the tir first, then if i’m not satisfied i will buy a xpg2
Can i buy a pill with xpg2 and driver somewhere or do i need to buy a complete flashlight?
i’ m not able to solder
Check out the beam pics in comfychair’s post here . The S4 with a dedomed XP-G2 seems to throw MUCH further than a S3 with XM-L2 (which I believe has the same reflector as the S2+.
Totally agree; you would not believe how easy (and rewarding) it is to solder your first driver to a LED/MCPCB. And the S2 is the perfect light to learn on since it is so easy to put together.
I swapped a couple S6s from XM-L2s to a 219B and a 219C, all at 2800mA. Both had increases in throw. Estimated intensities having calibrated my phone’s light meter using factory lights:
It’s noticeably more throwy, and makes the light a joy to use. The 219C is not the emitter to use to win numbers contests, but if you want a nice light to actually use on a daily basis, it would be my top pick.
