I am looking for a little advice please.
I have a wonderful Coast HP550 torch which I absolutely love. It’s a genuine 1075L and lasts ages on one set of batteries. However it has one big drawback. It’s quite heavy. For many applications this isn’t an issue, but I am using it for hiking and I really need to cut my weight down!
So I thought about buying some of these cheap Chinese torches. You know these ones with all the fake output claims! It seems that most claims are way off the mark, but often people seem to say that they are still quite bright. They seem really cheap, so I thought I could try and see if they would allow me to bring something less capable, but lighter.
So what I’m looking for is this:
- Runs off AA batteries - not rechargeable lithiums. (Easier to carry spares and interchangeable with other equipment).
- A genuine max brightness of at least 250-350L
- A dimmer mode that does 50-100L
- At max brightness a run time of 90 min + would be ideal, with 60 min really the minimum
- At dimmer mode a run time of at least 6 hours.
- 2 AAs would be ideal
- Zoomable would be nice, but if zoomable should be of a bulls eye design.
- Cost less than $10 delivered to Europe.
Let me explain these so that you can better understand my needs. I’d prefer AA’s that rechargeable lithium batteries as they can be easily swapped with other equipment when camping, and replacements are easier to get than it is to find somewhere to recharge!
The max brightness should be good enough that in an emergency I have plenty of light. I’d be far away from city lights, so I be dependent on enough light from this. Imagine my tent collapsing during a heavy wind/rain storm. (I hope that never happens!) I’d need enough light to be able to work comfortably, but would need it for too long.
The dimmer mode is what it would be used for most of the time. I’d use the dimmer mode for general camping chores, cooking and just hanging out etc. Six hours should be enough to get me through one nights camping without much difficulty. I should be well asleep 6 hours after dark. My Coast HP550 does 50L on dim mode, and that’s fine for general camping use. The Coast is zoomable which means that I can get more light on a spot if needed without having to go to high mode.
2 AAs- I figure two makes it last longer without having to keep changing half used batteries. Two isn’t very big or heavy. The Coast has 9 which makes it far too heavy! I’d be ok with 1 AA, but figure that will probably give too short of a run time.
The zoomable is nice for being able to see something far away temporarily. The Coast has a really nice zoom where the centre is focused onto a point, but there is still light around it. It makes walking in the dark easier as you can still see where you’re walking while throwing the centre of the beam further. I see some youtube videos of cheap Chinese zoomable torches but they zoomed everything to a spot, with little surrounding light.
$10 because I’m sure these aren’t going to last a long time, and I’ll probably need to carry a second one as a backup due to low build quality.
Do you guys have any suggestions? Do any of these ultra cheap Chinese torches match the requirements, or are they all rubbish?
Thank
Colm
