Can some one advice please what transformer specification I need ie amps etc
I have an approximate 3 meter run of 12 volt flexible strip light and I want to no the correct specs to buy a suitable transformer
Thank you in advance
12VDC, probably 2A or more would be safe.
Thank you for replying
I installed a 10M 2700k 24v outdoor light strip a few days ago. A 24v 6A dc power supply was recommended. I added a 24v 10A photosensor and 15A pwm dc motor controller in an outdoor rated 2 gang box. The cap on the right side of the box covers the brightness adjustment.
For a 3M 12V you might need a 3A or 4A dc power supply.
I thanks for replying
Depends on the kind of striplight. mono vs rgb, how many LEDs per meter, etc.
My come-with adapters for strips were all about 2A/10’.
Yeah, if you go for rgb, “high-density”, etc., you might have to kick that up a few notches. But plain ol’ regular striplights for me were about 2A/3m.
So… more info about the strips? rgb? mono? “high-density”? regular? etc.
Surprised they didn’t come with their own adapters…
Just in case…
Hi light bringer
is it possible you can look on this website it’s were I will be ordering my transformers from
So that I order the correct one s
Has I said I have a 3 meter strip 12 volt that just lights up and also bought a kit that sing dances and flashes but the transformer is to big so need to replace it with something suitable it has got written on it
Model number CW 120 1500 uk
Input 100-240 v-50/60 HZ
Output 12 v 1500 amp
This is the website that I will order from
Sounds about as naughty as banggood.com! ![]()
