A few weeks ago I was browsing AE and found a store that sold batteries and looked pretty legitimate. The store was named Aliyah or something close to that. I cannot remember the proper spelling, therefore I am having trouble finding the store again. Does anyone know of a battery store on AE with the name close to to Aliyah? If so, what can you tell me about it?
Hi, its called Aliya’s Battery Store and they have good reviews. I ordered cells from them on sale, upon arrival I will measure capacity to check if they are for real.
Yes that’s it. Thank you. Please share what you learn. Which cells did you order?
That store was recommended to me by other BLF members as reliable source. I ordered Sanyo GA’s 3500 mAh. They were cheaper there than at Fasttech and BG.
Yes, I bought altogether 30 pieces of 30Q from Aliya. Genuine cells. Good service. Free Button Top upon request with purchase of 10 pieces or more.
Thanks to BlueSwordM recommendation in one of the post here.
Another seller is Lucky Electronics Store in AX.
I have seen Lucky Electronics Store and wondered about them. Thank you
Can someone link to Aliya’s Battery Store? Searching does not get anything close.
Thanks!
More info:
INTERNATIONAL Here we go again with the insane shipping rules regarding shipping laws. Same stores again. Sunway Store: https://sunway.aliexpress.com/store/group/Battery/3173029_512165822.html Aliya Store for more variety in cells with slightly higher prices: https://www.aliexpress.com/store/1382210 Lucky’s electronic store: https://www.aliexpress.com/store/1191644 Vruzend: https://vruzend.com/international-orders/ AUSTRALIA Tech Around You Website: https://www.techaroundyou.com eBay:…
Soooo, UPDATE I finally received my 18650s from the Aliya Battery Store: https://www.aliexpress.com/store/1382210?spm=2114.12010612.0.0.7a5b23dbkNLBYu And I can say that they are truly genuine, and arrived on time to Canada! [image] Proofs and pictures of legitimacy: 1. They all weigh the same, around 45,9g and 47,2g. [image] [image] 2. The NCR18650GAs have the protruding flat top, and the Samsung 30Qs have a 3 pole positive terminal. No problem there. 3. The voltage of all 30Qs is 3,41…
So, now, some capacity tests! I’m using my own battery holder with my own large Beryllium Copper spring, which allows accurate capacity testing up to 3A without a 4 wire method. -I first started testing the NCR18650GA at 2A current, with a charge voltage of 4,185V and ending voltage of 2,6V. Capacity at 2,6V, being 3308mAh. [image] Energy at 2,6V, being 11,56Wh. [image] Capacity at 2,8V to compare with HKJ. [image] Nothing checks out, so I can confidently say NCR18650GAs from the Aliya …
Aliya’s Battery Store and Lucky Electronics Store must be closely related: same products, almost identical prices, same shipping costs (for me, YMMV), same product photography (only difference is the imposed shop nr.), almost identical spec sheets and shop rules… 1 shop with 2 different front doors?
I noticed that too. When one change shipping cost, the other change at the same time.
The ordered Sanyo GA’s just arrived. From visual perspective they look original with clean, precise wraps. The positive terminal is semi-flat top, very slightly raised and has three “prongs” that connect it to rest of the battery. Average internal resistance according to Lii500 charger is between 33-35 mR. Running a NOR test right now, will share results. I also ordered purple Shockli 21700 from Shockli store. This one does not fit the Lii500 charger, without hammering it in. Will resort to my DIY cable extension.
As promised, I run a NOR test on the Aliya’s Sanyo GAs ordered recently. They seem genuine, minimum capacity was 3492mAh, maximum 3607mAh. Will order again in the future, the cells seem legit.
Thank you all for the recommendations for this store. I just got INR18650-30Q, 4 pieces . These are original - without question.
