First off 300w isn’t very much power —that being said if your electronics have wal wart type power supply I don’t see a problem — One problem I see is the wires and the DC plug on this unit might not handle 25-30 amps continuous use
I would like to have heard the argument going on at the desk lamp company over the wisdom of selling and shipping lamps out at a loss vs market exposure and positive reviews.
The driver turned out to be different. Stock driver has a switch on one side, spring on the other - Quadrupel’s driver doesn’t have the spring - spring was on a separate PCB with the old classic Boruit style headlamps — oh well.
D25 style on top. Few style changes, and the threads don’t match:
So on the outside, very similar, but the inside - they combined the USB charge circuit with the LED driver on one PCB where before they were separate.
[/quote]
Instead of doing all that work , would not it have been easier to take the light off the headband and replace it with one to your liking ?
Not sure I understand. There was no work involved on this light, and these single 18650 single/dual running Anduril 2 with a nice warm LED with preferred optics doesn't exist unless modded.
Coupon stacking doesn’t seem to be working like it did before, they have added a feature to prevent people getting near free items by setting a max discount %, but I found that if I first applied the vipon coupon at checkout, then exit check out, delete item from cart and then re-add the item but now with the “save extra xx%” checked, it would still stack. But it’s been a long time since I came across a crazy good deal.
Every now and then you can get a great deal but most of the time no double hits —- might be a good thing though—keeps me from buying things just because
