MSRP: $60
Sale is as is!
Battery not included!
The Amutorch XT35 is a compact, 18650-powered tactical thrower flashlight derived from the host of the Amutorch BT35 LEP.
Core Specifications
• Emitter & Optics. Features an SST-40 emitter, smooth aluminum reflector.
• Dimensions & Weight. Measures 130mm–132.2mm in length, 35mm head diameter, and 25.4mm body tube diameter. Weighs ~110g–114g without a cell.
• Battery Compatibility. Runs on a single unprotected flat-top 18650 Li-ion cell. Protected or button-top cells are generally too long for the dual-spring battery tube.
• Charging & Protection. No onboard USB charging. Rated IP68 / IPX8 waterproof and 1m–2m impact resistant, with low-voltage protection (flashes at 3.0V, cuts off at 2.96V) and zero standby drain.
