great idea!, I also hate 5C momentary, thanks for pointing out it is not active in Simple Mode.
Actually, I always modify my simple mode in such a way that it does what advanced mode does - brightnesses and steps and ramps and turbo behavior and such stuff. So I actually have a simple mode which is like advanced mode, with a few exceptions - and one exception is that momentary and all the blinky stuff is not there. Wonderful. Some things are a bit different in simple mode, like Bat Check blinks only once, which is fine - and, of course, for programming, I sometimes have to go to advanced mode.
Just watch out, as with Extended Simple UI, there will still be Momentary Strobe Mode:
Then again, ToyKeeper has removed strobe/mood mode access from Extended Simple UI, so this should be history with the next Anduril 2 release.
wow, I learned something new… you are correct, my D3AA has Momentary Strobe in Simple mode
good…
and in Advanced, it will be good when blinkies have thermal step down
and it would be good if Strobe does not use Turbo, when Turbo is disabled from the ramping outputs.
