Thank you I will look into it
Do you know anything about wiring up drivers
A little, but if you have a general question it might be better to start a new thread.
Ok thanks
I was wondering about wiring both negatives from 2 channel driver to single channel mcpcbā¦ what would happen
Probably wouldnāt make any real difference. Certainly wouldnāt give you more output. Just wire the first channel (with the direct drive FET) to a single channel MCPCB and it will have the same performance as if it was a single channel driver.
Ok thanks for the tip i didnāt think it would work in that way either
Posting here instead of in the D3AA driver topic since itās generally more Anduril related
3 channel LED driver :
- 2.4V-5.5V
- operating current : 80/120uA typ/max
- shutdown current : 1uA max
- regulated current options : 25, 15, 10, 5mA
- 8bit PWM dimming : 20uA steps at 5mA full scale
- IĀ²C
- DFN 2x2mm
- dirt cheap
Depending how it can be programmed that looks like a good candidate for rich RGB
edit : 500Hz PWM frequency, could be better but for AUX LEDs itās acceptable.
I2C and 2x2mm package sounds really nice. Theres a lot going for this chip.
Yeah, this seems like a great one. Would be nice to have smooth aux.
So is the D3AA shipping with the 2024-04-01 release? Dark mode jokes aside, itās the only release up on github which contains the code for this new light.
Just curious and happy to see continued developments here.
0161-2023-12-03-2
. The -2 indicates it has two extra commits to the source code after that release, which so far @ToyKeeper hasnāt pushed to GitHub.
TK: Reminder the D3AA is in peopleās hands now - I want to take a look into the D3AA specific changes myself too
Most / all of them are in the dark mode branch IIRC.
Is there a way to change the batt check readout to 1 digit after the decimal ? Like in previous versions. Coudnt find any info in the user manual on github.
No, this is not currently user-configurable. Do you have access to flash new firmware? If so, it can be turned off in the code:
Hereās a build without USE_EXTRA_BATTCHECK_DIGIT
, no other patches or mods.
Many thanks for this build. Very helpful. Gives me the only chance for a new Anduril version on my lights, without this multiple digit voltage thing - which I personally find confusing, completely useless, and an irritation.
I must admit that I donāt like the extra digit either, but Iāve gotten used to just counting the first two and ignoring what happens next. To be honest Iād much prefer a system of one to four blinks representing 25%, 50%, 75% and 100%. If I want to know the exact battery voltage I have a multi-meter, day to day I just need to know if the battery wants charging or not.
Thatās already implemented in Anduril and can be enabled during compile time.
Thank you, will have to look into how to compile it.
