Sorry, I canât do that in firmware. The brightness is determined by hardware, not firmware. So there are only three brightness settings:
High: Power on, internal resistor off.
Low: Power on, internal resistor on.
Off: Power off.
It can control whether the power is on or off⌠and whether the control chipâs internal resistor is added into the circuit to reduce brightness. But it canât control how much.
Instead of a few short menus attached to the mode they configure, at 1 to 3 items each⌠you would prefer one long menu with about 10 to 20 items?
At last count, there were 21 config values⌠of which about half are set from a menu and half are set using some other action. The number changes over time though, as things are added and removed.
How would people configure lights which are physically incapable of this?
It uses âhold while connecting powerâ for factory reset, on most lights⌠so it would need another way to do that. And it would need to be really easy to do, since itâs a safety net for new users.
The idea for the simple UI is that most people wonât have to configure it⌠just take it out of the box and turn it on. It has no config options unless the user goes to the advanced UI.
After going to the advanced UI, theyâll be able to configure some settings for the simple UI. However, after going back to the simple UI, it will again not allow changes.
One way to do a power-on/hold the button config and reset, is to do it in 2 timeouts:
3 second hold to enter config mode
5 second hold to reset to factory
At 3 seconds, you could blink, say twice, then the user releases to get into config. If they continue to hold for 5 secs, it does the reset.
Now once you get into config, defining how it works to control 21+ settings (add all those being requested), and it gets insane not sure how this could be accomplished with an intuitive UI, accept maybe use the standard UI with the current config settings. A normal power-up sequence would have no config settings.
This might actually work out well, usability wise, and be relatively easy to implement since it uses the current UI for config settings. This is kind-of/sort-of what TK is saying above with the "simple" and "advanced" UI.
TK - I'm not so clear on this. The new voltage reading code, I assume will still be in Vers 2, do you believe it to be good enough to not need individual calibration?
I still have my older Anduril variant with added voltage calib (internal ref only for 1S battery, not voltage divider use for 2S+) and wondering if it's still useful, or are you considering adding it.
It still needs individual calibration. Itâs very stable and consistent now, but if the sensor isnât calibrated right, itâll be very consistently the wrong value.
So I have a voltage calibration function on the todo list. Itâll probably be a numeric entry menu attached to the battcheck mode.
My apologies if this has been suggested - I havenât read through the entire thread. Iâd like to see an option for the lighted switch to have a battery check option. So rather than a simple, steady blink, the switch will periodically broadcast the battery voltage.
To clarify, this would be under the current aux/switch options.
Iâd like a timer mode like candle mode but with just regular brightness, maybe swap it for one of the annoying strobe modes nobody uses or likes, oh and a working muggle mode.
Iâm adding a sunset / auto shutoff timer which works in both the ramp mode and in candle mode.
Trying to decide what the button press should be to activate it. In the old version, it was 3C to add 30 minutes⌠but 3C is already used in ramp mode, to change the ramp style. However, there is nothing on 4C yet, because I moved the config modes.
So this gives me a few optionsâŚ
Use 4C to activate sunset timer. Also adds 30 minutes. (or maybe just 10 minutes?)
Use 4H to activate sunset timer. Adds 10 minutes per second until the user lets go of the button. Blinks each time to make it easier to keep track of.
Move âchange ramp styleâ from 3C to 4C, and use 3C to activate sunset timer.
Canât use 2H because thatâs used for ramping down. Canât use 3H because that does tint ramping. So 4H is the shortest hold action available.
For testing, I have it set to 4H⌠but Iâm not sure if itâs the right choice.
There should be an easy way to adjust beacon brightness. I imagine this is a useful function e.g. when having a car breakdown or worser, an accident. But then is should be easily adjustable by press & hold and double press & hold. Right now I not even have an idea how to adjust it. Iâm using manual memory. And the pulses should be shorter. While at it, it should go to the other blinkies-set with memory.
