Hello everyone again, I will still only continue reading from time to time for my health, a shame!
I would like the default temperature to be 55°C so that with each update I don’t ask for the file to be modified and compiled.
I didn’t ask for it again so as not to disturb.
I have several flashlights with anduril 2.
TS10
SC31Pro
TS11
TS25
Every time I restart I have to configure 55° ceiling and it is complicated, I never know if I achieved it because it cannot be verified.
In the TS10 I had a problem on an outing, it was worn in the cap, it is comfortable, it is not heavy, but one of the times when trying to put turbo from the cap, it stayed fixed on turbo, I don’t know how I got there.
But if I turned it on it would enter the normal level and then go to turbo without touching it.
I couldn’t get out of that mode and it wasn’t turbo mode because it turned on in normal mode and went to turbo, so the fixed turbo mode doesn’t work.
Well, since we were on a night out I had to restart the flashlight and I lost the 55°C ceiling.
Since it was summer it was about 35° and the flashlight reached 45° in seconds and the light continually decreased, I couldn’t use it.
I would like it to be 55° by default, I think all brands without anduril use 55°
That way I wouldn’t have this problem, it would return to 55° each time it restarts.
I have seen videos and the first thing they do is raise the ceiling temperature, I think no one uses the value of 45° and less in warm areas.
The other request is the strobe mode in simple UI with 3C so that children and adults can have fun.
I gave the older flashlights with anduril with advanced UI to use the strobe mode but it is very complicated for those who are not used to entering with 3H.
They ended up changing other things about the flashlight.
In short, chaos.
The next day I bought flashlights from a Chinese bazaar 1C lit 2c strobe.
Nobody wanted my flashlights with anduril, everyone used the cheap flashlights ![:sweat_smile: :sweat_smile:](https://budgetlightforum.com/images/emoji/google/sweat_smile.png?v=12)
I think that in simple UI there should be nothing not even the battery value, just turn on, turn off, brightness levels, turbo with ceiling and strobe
Thanks, I’m glad to read you again!
PS: Remember that I use a translator ![:man_facepalming:t2: :man_facepalming:t2:](https://budgetlightforum.com/images/emoji/google/man_facepalming/2.png?v=12)
