Prior to the recent reflash of this TS21, there definitely wasn’t any audible clicking, at least relative to what’s happening now. I just noticed that the noise increases/decreases as I ramp the affected Strobes up or down, which makes sense!
Ultimately, the noise being made is no big deal, I was just interested in knowing the cause. So I appreciate your explanation!**
MAKING THE TACTICAL MODE GROUP STROBE PERMANENT/SEMI-PERMANENT I don’t want my Tactical Mode Strobe to inadvertently change because I forgot that I had changed the last memorized Strobe I was using while in the non-Tactical UI.
So that scenario begs the question, would it be possible for you, TK, or someone else to program the Advanced & Tactical UIs in a way that would make it possible to keep the Strobe chosen for the Tactical Mode group to remain unaffected whenever the user chooses to use a different Strobe while they are in the non-Tactical group of Blinkies?
That’s what I meant with “After the first 150 levels it continues with the strobe modes”. 151 is the first strobe mode, 152 the second and so on. Instead of 150 short presses do 15 long presses.
Yes that wurkkos-ts10 file will work. The original firmware that shipped was built for another light, model 614 sofirn-sp36 (reference).
But there is also a newer version available if you follow the instructions mentioned in this post to download the latest zipped files from github: Anduril moved to GitHub - #47 by dognodding.
Does anybody know what the pinout is for this A2 version of the LT1? All the guides that I could find for reflashing the LT1 are for the older 3:3 layout, or recommends unscrewing and pulling the driver out to use an soic8 clip. As yet I haven’t been able to find anyone who has done this layout.
I’m planning on just using a usbaps and dupont jumpers. So I should just try in numerical order? I’ve never done this without a guide. There won’t be any danger in trying that order? Just want to make sure in case I blow something up.
Post has been updated for 2024, seperated into two sections to accomodate the new updates for Anduril. Many new lights going forward will be using ATTINY1616 and AVR32DD20 controllers.
Hi, everyone!
I recently updated my Mateminco MT07 (MF01 Mini) flashlight to Anduril 2 (2024-04-20). Everything is super, but it detects the battery voltage 0.2-0.25V less. I would like to calibrate it, but I can’t. I only noticed later that after the temperature there is no Beacon mode, and no SOS. Am I right in thinking that because of the small flash size of attiny85, these had to be removed from the program?
Thanks for the quick reply!
And does it only affect the readout or will it turn off faster on discharge?
That’s probably not the feature I would have removed, but I didn’t read it properly. I don’t really feel like disassembling it again.
