ANDÚRIL UPDATING HELP NEEDED!
As recommended, I followed along with @liquidretro’s video tutorial for updating Andúril-2 by using @gchart’s Programming Adapter Key with the ZFlasher App with an Android phone.
Unfortunately, after trying everything I could think of, and checking in with @gchart and @jon_slider for suggestions (thanks guys!), I’m still unable to update my Wurkkos TS21v2.
Curiously, has anyone “successfully updated” Andúril-2 on their Wurkkos TS21 (the updated version with flashing pads) by using @gchart’s Programming Adapter Key with the ZFlasher App on their Samsung (Android) device? What issues did you encounter, if any, before succeeding?
In order to eliminate which possible reasons may be preventing the ZFlasher app from recognizing the Flashing Adapter Key, I now ask for your assistance by verifying or eliminating one-by-one, which of the following considerations are “absolutely” or “absolutely not” preventing the Flashing Adapter Key from being recognized by the ZFlasher app.
A) Should I be using a USB-C to USB-C cable “only”?
(I’ve been using my Samsung tablet’s USB-A to USB-C cable with both a cheap USB-A Female to MicroUSB Male OTG ADAPTER along with a cheap MicroUSB Female to USB-C Male Adapter.)
B) Could it be that the Programmer Key’s pogo pins are at best, barely touching the inside edges of the TS21’s two outer flashing pads? (I don’t currently have a way to take a photo of this, but hopefully this screenshot demonstrates the issue.
NOTE: I was under the impression that the dimensions of the pads were the same on both the TS10 & TS21. While the space between the pads may be the same, the pads of the TS21 must be proportionately larger. I don’t have a TS10 to compare.
C) Should my tablet’s “DEFAULT USB CONFIGURATION” (Developer Options) be left as “Charging-Only”, or set to one of the other options for this purpose? (Transferring Files, USB Tethering, MIDI, Transferring Images)
D) Is there anything else to consider?
As someone with very little programming knowledge, and even less actual experience, I would appreciate your assistance! Thank you!
