The bike algorithm is very simple… it runs at level N, and the pulses run at level 2*N. So, if it’s set to level 40/150, the pulses flash at level 80/150. However, it doesn’t limit the brightness to halfway up the ramp. It doesn’t stop at 75/150. The default allows it to go up to 120/150.
So it should then pulse at level 240, but there is no such thing. The light itself can only go up to 150.
In other words, no, I can’t make it brighter to make the effect more noticeable. It’s already going as bright as it physically can. If you want the pulses to be more visible, you’ll instead need to turn the brightness down. Like, instead of running at 120/150, maybe try turning it down to 90/150. Either way, it’ll pulse at 150/150, but that will look more noticeable when the base level is lower.
That … may be a bit excessive. Tail lights are usually not thousands of lumens. It’s likely to anger people behind you.
Have you considered using beacon instead? It has adjustable brightness and can run at 1 Hz…
Just bought sofirn sp36 anduril version and i’d like to use strobe cycles as momentary. Tried to power off while in strobe and 5C power on. Not working, did i miss something? Or maybe this light use an older anduril version? Any way to upgrade it to a newer firmware? Thanks for any input…
SP36 Anduril, as of the current time, still uses an older version of Anduril, without the momentary strobes modes.
(the same old Anduril version appears to be used by the Sofirn IF25A, Astrolux EC01 and Astrolux EC03).
I believe the SP36 Anduril can be updated to a newer version, and there is a pre-built hex file for it in TK’s repository, but my problem is I don’t think I can easily remove the driver (there are various tips & tricks mentioned in another thread here in BLF on how to remove the driver, but I think it’s bit beyond my skill level — I might break things and might not have the skill to fix them up).
I purchased two "SP36 BLF Anduril" lights this year from Amazon US in February and March that do not support the "15 or more clicks from off" Anduril firmware query.They also both have issues while in Muggle mode where they frequently ramp down to minimum brightness unexpectedly.
My Sofirn "Q8 BLF Anduril" light purchased this year from Amazon US in June returns a version date of "2019-09-28" from the firmware query and Muggle mode functions well.
My two Sofirn "LT1" lanterns (both with the newer "Rev. 5.0" driver board) purchased this year from Amazon US in June return a version date of "2019-11-29" from the firmware query.
Thanks for the info! The initial SP36 version was from late 2018, a version I sent as an early proof of concept but never intended for production. It was rejected at the time, so I didn’t think about it again until a user reported problems… We did some tests to determine the version, and the result was disheartening. So I bugged sofirn about it, and they started using newer versions.
Hopefully they’ll update everything to Anduril 2 when it’s ready. I mostly just need to finish the documentation.
I do agree and need to do more testing with someone else on my bike to better evaluate the possible nuisance for others but I’m using a bicycle rear light as my main red light and the FW3A with the red filter is pointed down to illuminate the bike frame in order to be better seen at crossroads by cars coming form left and right.
Yes since a couple of weeks when I realized by reading one of your message that the beacon was using the memorized ramp level. I tested beacon before, but as I generally don’t need a lot of brightness, the beacon was pretty dim. :person_facepalming:
All Right! Thanks for the info! I’m new to this and this is my first Anduril Flashlight. I love it! This UI should come with all the flashlights!!! I guess eventually, next generation flashlight will be updated via the usb port! I’ll keep an Eye on future version of sp36 and newer firmware since momentary strobe is an important feature for me….
Could you tell me what is the rewind speed of the discrete modes in the Lumintop EDC18?
I wanted to understand how quickly the modes change when the button is held down. 0.5sec … 0.7sec
The FW3A firmware has the max regulated level at ramp step 130 of 150… so 21 clicks.
As far as I’ve heard, yes.
To help with figuring out this sort of thing, I created a product and firmware map called PRODUCTS. Also, in Anduril2, the version check function includes the build date and vendor/product ID to identify which exact firmware was used. So in the future it should be easier to get this info.
If I recall correctly, it’s one HOLD_TIMEOUT unit of time per step, and the firmware for that used a HOLD_TIMEOUT of 24 frames. Each frame is 16ms, so that’s 0.384s per step.
I see in the Anduril manual that the default stepped ramp is 7 steps between “floor” 20/150 and “ceiling” 120/150 (+ turbo).
Is this default setting the same on all Anduril lights? And are the 7 steps equally spaced?
Also, it would be great if manufacturers using Anduril could publish the expected brightness of each of the steps, as per “traditional” flashlights.
The same on all lights? No, the ramp values are different for each build target. The ramp values shown in the manual are only examples.
Equally spaced? Yes, sort of. It’s equally spaced in terms of ramp steps… but what that means in lumens depends on the ramp shape. There’s a tool called steps.py which can be used to calculate exactly which ramp steps it’ll use. For example:
About what manufacturers publish, I’m sure we’d all like it if flashlight companies would consistently publish accurate data about their lights… but that problem is way beyond anything I can fix.
Thanks for the quick reply. I was hoping that something would remove the guesswork at approximating the lumen output at each step, other than referring to published reviews, or buying an integrated sphere.
