Hi,
Is it possible to set turbo mode as the 1st mode on Anduril v1 (e.g 1 click - turbo, 1 click - off)
I just tried 5C on my FW3A with Anduril 1 and it only saved Ceil not Turbo.
You might have to adjust Ceil to 150 first.
Edit: I just tested it, if you set Ceil to 150 you can get instant access to turbo using manual memory.
From On, click 4 times to get into Ramp Configuration, after it flashes twice, click it only once to set Ceil to 150.
Then from Turbo click 5 times to set manual memory.
It works!! thank you!
