Hey flashlight friends
me (and my GF) have been working on something small for all flashlight modders.
Many, including me, werent able to get an IDE including the compiler running for Anduril2 modifications.
And even if you did, you had to search through dozens of config-files to find the right setting
Introducing:
A project that aims to make all the above simpler and faster.
The Github project includes a ReadMe and so far only runs under Linux, maybe it does run with WSL/Docker for Windows but it wasnt tested
When you open the webpage you have a list of all buildable cfgs in the left.
Click on build to build it or click on it to open the right side of the window.
There you have all parameters that the selected flashlight is using, you can modify any of them and press save in the bottom right and then build it with your changes.
You can upload your own custom hwdefs and cfg files on the top left or reset everything to defaults with the button on the top right.
If a build fails, reselect the flashlight to show the log files under the configuration options
Hope this project can help atleast a single person and hopefully many more
