Product Description
Utilize CREE XML2 U4 LED with lifespan up to 50,000 hours burn time;
Powered by one 18650 battery and two CR123A/16340 batteries;
Avant-garde design of main light and secondary lights for widely use(Patented);
Mechanical rotating bezel design for multi-colored LEDs changing(Patented);
Digitally regulated output maintains constant brightness, reverse polarity protection;
Maximum 600lumens with beam distance up to 100 meters and 38 hours runtime;
Secondary multi-colored LEDs are for widely use with maximum runtime over 45 hours;
Additional warning and strobe light function to meet your outdoor safetly requirement;
Quiet noise click button switch for power on/off and light level output control;
Made of durable high-grade aluminum, Type III hard-anodized anti-abrasive finish;
Lightest-weight (108g battery excluded) and compact appearance design(size 76x43x32mm).
FEATURES:
Main lights+3 x secondary lights design(Patented),main light is for throwing long distance beam, secondary lights are for short distance with widely use.
Compact and smart housing design can be rotated wide range up to 100 degrees with one hand operation.
Main light: 600lumens maximum, 100 meters beam distance, over 38 hours run time
Rotating bezel design for multi-colored LEDs changing(Patented); Secondary lights:80 lumens maximum, over 45 hours runtime
Secondary multi-colored LEDs design meets outdoor widely use;
No noise click button switch design;
Power on/off; control multi-brightness and different operation functions output;
Warning mode with double click; Strobe mode with long press
Micro-USB waterproof charging plug, the indicator is red when it is charging and green when the battery is full.
Please note:it can’t be charging directly with two 16340 batteries in it.
Optional accessories: Angryfox battery, charging cable.
