From Random.org The winner is Post #136 member name; eta
Congratulations! PM me with your full name and address, so I can ship the light.
With a about month gone by, I have decided to go ahead and pick a new winner. My decision, good or bad.
The New Random.org Winner is Post #49 raccoon city.
Thanks to a very generous member here, I received a Solarforce L2m host. I added a generic P60 drop-in with an XM-L T6 3C and a 2.8 amp, 3 mode (no memory) driver. I added a shim to make the drop-in tight and added some copper rounds under the led/star shelf. I believe this was a new light. Here's a couple photos.
The body/head seam has a green O ring on it. I will not call it GITD, since it does not glow. The O ring is there to keep the two pieces from touching. This solarforce has been made poorly. The head or body was not bored/threaded correctly. One of them is off center and if you screw them tight there is enough mismatch that you can't get an 18650 in. With the O ring in place you can. I have tested it and it works. I have a dummy 18650 to test with.
The XM-L is off center, shoot me... It still works and looks fine.
Anyone who was a member Before February 15th, 2013 can enter this giveaway.
Enter only once, by posting here...
You have till 02-20-2013 at 8:30PM CST to enter. I will pick a winner that night, maybe not till I get home after Midnight, but the giveaway ends at the date and time listed.
I will use random.org to pick the winner.
Have fun, be lucky
