I reckon I’ve just crossed the threshold into being a flashaholic. I’ve been lurking for a good long while… I think is my second post. But through the awesome guidance and information posted on here, I’ve built something like five C8’s (with several being subsequently taken apart and put back together again to improve output) and several P60 dropins. Even dedomed and reflowed a few LEDs onto Noctigons. Before starting this new hobby a few months ago, I could barely operate a soldering iron.
So building flashlights from hosts and parts is one thing… but here’s the line I’ve crossed: last night I took apart a perfectly functional Streamlight Stinger DS LED, removed its LED and leads and replaced them. After some of the C8’s I’ve built (with added 7135’s, most are pulling around 4-4.2 amps at the tailcap on high), the Streamlight doesn’t get used hardly at all due to its comparatively weak, narrow beam. Here’s how it went.
For those unfamiliar with the light in question: http://www.streamlight.com/product/product.aspx?pid=135
Before surgery:
No idea what this LED is.
Here’s the battery pack - not sure how many cells, but they’re in parallel. Fully charged it reads something like 4.1V
Reflector off
After taking out the retaining ring, here’s the LED, with some AA slathered underneath. What for, I’m not sure. The pill is entirely made of plastic (wtf?)
Pill comes out when you unscrew the charger contacts
No turning back now!
Close up of the driver:
New LED leads attached… the tiny old ones were through-mounted and were a huge pain to get out.
The plastic piece that previously held and centered the old LED can be cut down to hold the new LED (a dedomed XM-L2 U2)
Added more arctic silver, got it centered as best I could and cranked the retainer ring down tight.
Miracle of miracles… it lives!
Driver put out some funky burning smells when I tested the current to the LED, so I haven’t stuck it back on the charger yet to verify that still works as normal, but I reckon it ought to. Current to the LED before the swap was right around 0.9 amps. Forgot to test it after the LED swap. Seems brighter. Output & throw is similar to one of my modded C8’s on medium. Beam shots to follow.
