I didn’t really count how long it takes to turn my JKK03 off, but the delay is long enough to annoy me, as I can’t instantly turn off the light whenever I want to do so.
Here is JKK03 with SMO reflector + Nichia 144A
The worse part is the hotspot, where there is an obvious “egg yolk” effect.
Below is the same setup but with a OP reflector.
OP reflector won’t eliminate this issue but the effect is reduced.
(FYI the type of OP they use is rather “mild”)
I’d like to know more about this JKK flashlight with powerbank feature.
Would the JKK03 be similar (slightly stouter) to the Sofirn SP33 / Convoy S11 in size?
And the JKK36 is maybe similar to the Convoy M3 in size or smaller?
What’s the main difference in terms of beam pattern of the JKK03 vs JKK36, assuming the same LED were chosen in both models (eg. both are using XHP50.2 or both are using XHP70.2)?
Just ordered the new model JKK36R (4000K) USB type C cable included from Ali.
Says they changed the mode pattern to Low-Medium-High.
Funny but I already have an XHP70.2 4000K in both an upgraded Magicshine style bike light clone and a fairly new KDLITKER BL70S, and wouldn’t describe either as Warm as listed on Ali (KD says NW for 4000K and I agree.) Though for some reason those emitters in my two mismatched lamps don’t seem to share the same exact tint, maybe the binning is slightly different or the larger reflector on the KD makes it seem a little more creamy. In any case both have very good color, can’t imagine the 5000K emitter offering any improvement.
Also have a couple of the JKK03 4000K on order from KD, am hoping to be able to fit 39mm wide angle lenses inside their bezels to smooth out their beams with minimal loss. Would install them with the grooves running horizontally to produce an elongated spot rather than wide ellipses so they’d still be pretty throwy. (Diffusing film I applied to my BL70S does a great job eliminating rings but kinda kills the throw.)
Will be a while before any of these flashlights arrive but will report back then.
I have the JKK36 from aliexpress with OP reflector and at least outside there is no such effect visible for me. It is definitely larger than the Sofirn SP33
However, for everyday walk I prefer the JKK70 4000K OP with the 26650 Battery, which is somewhat smaller than the Convoy M3. Light Output in the wild is similar, though Convoy claims more lumens (4300 vs. 3600). However the M3 is built like a tank with considerable higher wall thickness of the battery tube, thus making it also heavier.
I have a March K3 with a SST-20, I will probably swap it with a boost driver and 144A. If the beam is still bad I might have to try those pebbled TIRs.
