Okay. The suspense was killing me. I got the 3410CC to try it out. The basic 3310CC is more in my wheel house but the 3410 has all the bells and whistles for around $40 and I was feeling skeptical. So far, I’m pleasantly surprised!
This flashlight is extremely versatile. It has ten modes between two LEDs. It has H-M-L in spot, flood, or both; and a blinking mode in spot only. The blinking mode is not part of the main rotation, which I think is good for most people. The UI could be a little daunting because everything is controlled from one button. This can be an issue with any multi-mode flashlight running a ton of modes but here especially, I wish there was a second switch or button to simplify changing modes versus changing LEDs. Given that this is more a utility flashlight as opposed to an EDC or tactical light, that becomes less of an issue. On the other hand, that also makes me wish that the rotation started low instead of high.
As a utility light, the 3410CC is awesome. It glows in the dark. It can stand on head or tail. The head can be rotated ninety degrees or a bunch of places in between. It has a spring clip for carrying around. It has a key ring at the top of the clip near the head. It has a lanyard that can be attached near the tail. (The lanyard bead is shaped so that it can be used as a tool to help open the battery compartment.) The clip has a magnet that sticks very well to appropriate metal surfaces. This means that it can be hung or mounted in all sorts of places and can provide different kinds of lighting for extended project use. Then it can just as easily go on a walk through the woods at night.
Speaking of light and the woods, this flashlight is a rock star! It’s 2700K and 90+ CRI according to the manufacturer. I believe it. The diverse greens, tree barks, etc. of the forest really pop! This helps the spot reach out into the woods a little too.
Shining spot mode against a white wall, there is some color variation in the beam pattern. I thought that was a flaw at first but the more I used this light, it helped provoke nostalgia for the variance of incandescent bulbs. I didn’t notice it in a woodland setting but I’m wondering if it made a background contribution to the liveliness of the visual picture.
This looks like its going to be an excellent general purpose flashlight. There’s just so much that it can do. There might be other flashlights that do specific things better but this is probably the most versatile flashlight I’ve seen IRL. It should excel as project lighting. For “normal people” who don’t collect flashlights, this could be a great primary flashlight for around the house, at camp, a garage, a workshop, etc. (In that role, this could be a stellar gift idea.)
That said, this definitely isn’t an EDC light. For a regular walk at night, I’m still going to reach for a more straightforward flashlight with a simpler UI. Based on my positive experiences here, I think the 3310CC might be a contender for that.
