Yes - looked at the maxtoch SN6X-2S from the listing and it does look very good, seems to be a quality light, good heat sinking from the looks. Just de-doming an XM-L2 U2 1A could be up to 150 kcd or little more. Reflector, based on dimensions, may be same or slightly bigger than the standard HD2010/T08/T13/etc. reflector. A lot depends on what it's driven at and whether resistor modding is do-able or driver upgrade. The mod'ed T13's I've gotten 155 kcd from, T08's and HD2010's 200-210 kcd. The 2 cells in series lights are a different ballgame for modding - resistor mods or high performance drivers is the key to high output.
Things lacking, maybe:
- would like to see an SS bezel on this unit - step-up in quality, functionality and looks
- AR lens is not mentioned, so probably doesn't have it (not sure if a standard size will fit it)
Edit: Ooops see the previous threads on this light - about 3A to the LED which is pretty good, and see you de-domed them with good results, up to 180 kcd, cool!!
Wow so many choices its hard to pick one… thankz for all the help everyone ill post here which one i decide on .i really like my hd 2010 but the more a light throws the better for me
It’s the earlier version of the Maxtoch SN6x-2 (57-64k stock) we have running at 175-177k. These make brilliant hunting lights with light weight (250gms), good runtimes, and the huge throw - 859 meters ANSI. Have not yet done this new SN6X-2S (63.2mm head) but with its higher output stock at 69-72k, modified it should be nearing 200k. May not need modding at all.
I do have one of the limited edition SN6X-2X maxtochs Tatasal mentions. Its a bit bigger at 10” long and 442 gms, has a 68mm head, and stock reads 89-92k. Manualman modified mine with dedoming, variable resistor etc and its output is now 230k, with 73 minute runtime on panasonic 3100s.
Maxtoch bringing out a lighter weight (300gms) version of the 2S this year fitted with XML2-U2. Will be ideal for hunting and stock output should be 75k or so - good performance for the buck.
