Can confirm, at least in my case the 1300 lumen version bearing the model PMZH61 tail cap does “grind” on the negative terminals of the batteries, even cuts them in some cases. It is huge as well, may be not that far from the 900 lumen version however.
The 400 lumen PMZH21 does not however do the same but has its own issues.
The Energizer 1300 is worthless in design factor. The battery compartment is built in with connection studs protruding to make contact with tailcap. The tailcap rubs or crushes the battery with major dimples.
I disliked design so much I actually gave it away.
