Any idea how to fix this?
I have this Xtar MC2 battery charger and the other led is only displaying red with a little bit of green if you look at it from one side.
That channel still works fine but it just gets confusing sometimes if I charge a battery and I have no idea if it’s dead or if it’s actually charging.
Has the LED got 4 legs? E.g. is it an RGB one?
This is a 5mm one, but you may have a 3mm?
It’s a 3 leg 3mm.
The thing is, the led can still turn fully green when it’s done charging a battery so I’m not sure if it’s the problem.
Swap the 2 LEDs, if the issue follows the LED you’ll know for sure.
