Does anyone have any ideas for a flashlight tripod?
Or how to attach various shaped and sized flashlights to a regular tripod?
I bought a tripod for my camera to take beam shots in different locations but I would like something steady to hold the light as well. Preferably something cheap.
I've found using a conduit clamp mounted to a tripod top works great (use 1/4" x 20 nut). I even use a wingnut on the bolt for quick release of the flashlight. Here's a similar idea using 2 conduit clamps (back to back) for a bike mount:
(Please don't judge me based on these two lights shown. They were at the beginning stages of my flashaholism and I hadn't moved up to Li-Ion yet.)
I might end up doing that if I can’t work out something simple to attach it to the 1 tripod. I didn’t really want another tripod as I only have a single room and my car to keep things in and space is very limited but its a option that I might have to do anyway.
Split a piece of pvc pipe, after figuring out which diameter works best for you. Drill a hole about a third of the length used (mine’s made for D MagLights, so it’s 2” pvc about 8 inches long), tap it, thread it straight onto the tripod. Lets me lay one light after another in the halfpipe for direct beamshot comparisons while maintaining the focus point on each light. If you’re shooting a steep angle, a heavy rubber band holds the light in place easily. I also didn’t split it straight down the middle, but rather closer to a third for a shallower halfpipe for smaller lights to also fit.
