Anyone here own a P-Rocket XM-L?
Was browsing Shiningbeam's site and saw this, the stats look good and at $47 i is not a bad buy-especially if you get a 6% CPF discount. What really caught my attention was the neutral XM-L. My S-mini has that and it is a very nice tint.
Nice to be able to use 2xCR123's as well
http://www.shiningbeam.com/servlet/the-97/**NEW**--P-dsh-Rocket-XM-dsh-L/Detail
** This latest version has thicker heat sink and smaller size**
** Compact size flashlight specially designed for bikers**
* Features a premium neutral white Cree XM-L T5 emitter, 4C bin
* 810+ LED lumens on high mode
* Square threads for smooth battery installation
* HA III anodizing
* Comes with tactical momentary-on switch and regular switch
* Voltage input 2.8-6V
* Compatible with 1x18650, 1x17670, and 2xCR123A
* 3 Modes: Low > Mid > High
* Current output: 140mA on low, 1000 mA on medium and 2800 mA on high
* Regulated circuit for constant current output
* Built in Voltage protection, will cut off at 2.8V
* Reverse-polarity protection prevents wrongly installed batteries from damaging the circuit
* It can tail stand
* The memory feature will memorize the last mode
* Toughened ultra clear glass lens with 98% transmission rate
* Extra thick body for good heat dissipation and excellent durability
* Orange peel reflector for smooth output beam pattern
* Comes with accessories: holster, 1 spare tactical switch, lanyard, O-rings, and G.I.T.D tailcaps
That looks really cool.
I like the small size and the widely spaced modes 1 amp medium should be nice and bright and 2.8 amps should be the rocket part- almost overdriven.
Like to see some beamshots.
Hope it's not too sharp with the "attacK" bezel that attacks your pocket.
Runs on different batteries, warm tint for inside on lower modes-and the 2.8 amp turbo - nice!
I don't. Looks sharp. Oh, wow, T5 emitters? Since when have those been out?
I ended up buying one, did a review in another thread. It is a nice, warm XML beam.
How does this compare to the UF-2100?
nope but i'd want one :) 4c ftw
