Hi,
Thanks. I was just able to do the replacement. I still can’t believe that they expect you to do that, but I’m glad that it’s working again now. I think that the next time it goes bad, I may have to replace the whole pencil+cable ass’y (explain below).
As you said, there’s a long single-sided PCB that the 4 leads from the element has to be soldered into. In my case, there was one lead with blue insulation and another with gray insulation, and then 2 other leads that were bare stranded wire (fairly thick).
I matched the wire insulation color up with what was already soldered in and then tried to figure out which of the bare stranded wires went where. One of them has a short cloth-like sleeve and the other doesn’t so I went by that.
The through holes going down the board are in pairs. What I mean is that there are pairs of holes that are tied together.
The original wires went into one of the holes in a pair, and the other hole was left open… I’m guessing that is because that avoids having to desolder the wire before putting in the new wire.
So, I took advantage of that.
I cut the existing wires at the heating element end, so that the wires were still there and going to the right hole. Then, I routed the wires from the new heating element to the paired holes and made them taut, removing as much slack as possible so that, as you said, the wires would lay flat.
After double- and triple-checking, I then soldered in the new wires from the new heating element, then cut the remainders of the old wires off the board.
Then, I re-assembled the pencil, and powered the Aoyue up and held my breath… waiting to see what happened.
Voila! The display came on, and the display started climbing to my set temperature!!
That was it. I now have a soldering iron/station back again, at least until the next time.
Thanks for your help! The key was that you confirmed that I had to solder in the new heating element. As I said, that was something that I didn’t expect to have to do.
Jim
