not a big deal but I found, no really I found them. they are used (retreived them out a bissle dust buster)
10 4/5sc nimh cells, I charged them up and all seem to be just fine.
I cant figure out what to use them for.
2x do fit and run my S7 lights maybe put them in your zombie bag?
they are 1.2v each. they dont run the s7 as well as an 18650 but I did stack two togther to charge them on my li-on charger.
if you look up nimh charging you will see that temp is most often way to manage the charge and I just got them warm and up to around 1.4-1.5v pulled them off and they cooled n problem and voltage stabilizes well.
I bought some a few years ago and used them to convert 6V Vistalite nightsticks to 8.4V. The original cells were 5S subC and I was able to squeeze 2 more of the 4/5 subC’s into the tubes. Capacity of even new cells isn’t great though.
•High quality 4/5 Sc size, 1500 mAh Nickel metal hydride (Ni-MH) battery with flat top.
•Each cell is individually checked before shipping abd all the batteries are matched.
•Ultra high capacity, 40% more running time than Ni-Cd Sc battery.
•Very long cycle life and Rapid battery charge up
•Significant savings (60 % or more) from any retail stores.
•Battery tested based on International Electronic Commission (IEC) standard to ensure capacity, quality and life time 6
Technical Specifications
•Dimension: Height 34 mm, Diameter 23 mm
•Weight: 43g
•Capacity: 1500 mAh
•Voltage: 1.2V
•Single Cell Resistance =16 mohm or below
•Standard Charge: 16 hours at 200mA
•Rapid Charge: 2.5 hours at 1000mA
I put 30 of them in a Pelican King D. The nice hing about them is you can series them to get whatever voltage you need without worrying about protection circuits.
