But….
I seem to be obsessed with finding out not so much the question I posed in the OP, but the opposite, i.e., can a light with an MT-G2 be really throwy.
But….
I am also impatient (not nuts, but may impatient) to try to find out the answer to that question.
But….
None of the new MT-G2 lights, except maybe the ones we haven’t seen, like the Niwalker, seem to be purposefully designed to be throwy.
So, combine all of the above, and it doesn’t look like I’d be able to get an answer to my question if I just sit around waiting…
And, I think that I am still new enough at all of this that if I do something really stupid, I can claim that “I didn’t know that”…. “Ignorance is Bliss”, as the saying goes….
So, I did this kind of weird “lego-ing” experiment tonight.
Components:
- Pill: CPF MT-G2 (from this thread)
- Head/Reflector/neck: DST (see garry bunk’s giant DST thread)
- Body: Clone A8 (see garrybunk’s giant DST thread)
- 2 x Efest 18500 batteries (fully charged, ~4.20V)
I put all of those pieces together to make a “new” kind of Frankenstein-ish combination of a shorty DST and an MT-G2 light.
The pill from the MT-G2 light was slightly smaller diameter than the DST pill. I was originally guessing that the pills were the same size, but they weren’t, so to get the pill from the MT-G2 light into the DST head/reflector, and to provide contact from the emitter to the body, I wrapped it in aluminum foil, and shoved it (really hard) into the neck of the DST, then carefully screwed the DST head down, watching the MT-G2 emitter as I did that, to make sure that it stayed centered.
It took quite a few tries, but eventually, I got the head screwed down, and the emitter somewhat close to centered (see pic below).
I then screwed the clone A8 tube onto the DST neck, dropped a pair of 18500 batteries into the tube, then screwed on the clone A8’s tailcap.
I tested the “new” light with a pair of Trustfire “flames” 18500s first, just to make sure it worked.
It did, so I was ready to test, so I put in the 2 Efest 18500s.
Test setup is the same as last night, 14 feet from light to lux meter sensor. Meter was set to “Max” mode.
Test results was 2070 lux :(…
Overall, I’m somewhat happy that I was able to get it working…. but somewhat disappointed in the results.
I’m also trying to tell myself that “this was just a test”, and to not generalize the results to the answer of my question, but, between the testing last night, and this light, and the results tonight, I’m starting to wonder if I already know the answer to my question :(…
Some pics:
The “Franken-dst-mt-g2” light:
The MT-G2 emitter in the DST head and reflector:
Edit: I forgot to mention: I did tailcap current measurement with the Efest 18500s in the light, and that was ~3 amps.
