Since 2 days ago, and due to this thread (Skilhunt M150 Lock-Out Function Current Draw?), I started thinking about some lights I have and started “testing” them. What they have in common is that all are e-switch flashlights.
The lights in question are: Skilhunt M150, Skilhunt M200 and On The Road M3 Pro.
Both Skilhunt lights have the possibility to do electronic lock-out and to enable the switch blinking red, as a way to find them in the dark. This possibility can be enabled or disabled. The OTR M3 Pro doesn’t have electronic lock-out.
I did a simple “test”:
- In the Skilhunt flashlights, I measured the battery voltage, put the battery into the lights, locked them with the blinking switch enabled and after some hours, I took the battery out, measured the battery voltage again. After this, I put the battery into the lights again, locked them without the blinking switch enabled and after some hours, I checked the batteries again.
- In the OTR M3 Pro, I just measured battery voltage, put the battery on the light and after some hours I checked the battery voltage again.
- During these periods, I didn’t turn the flashlights ON, and the only light that appeared was because the Skilhunts turn the light ON while being locked out.
What I got:
Skilhunt M150 (with blinking switch enabled)
Starting voltage = 3.68V
Voltage after 6 hours = 3.65V
Drain: 0.03V in 6h
Skilhunt M150 (with blinking switch disabled)
Starting voltage = 3.65V
Voltage after 10 hours = 3.65V
Drain: 0.00V
Skilhunt M200 (with blinking switch enabled)
Starting voltage = 3.81V
Voltage after 13 hours = 3.79V
Drain: 0.02V in 13h
Skilhunt M200 (with blinking switch disabled)
Starting voltage = 3.79V
Voltage after 10 hours = 3.79V
Drain: 0.00V in 10h
On the Road M3 Pro
Starting voltage = 4.11V
Voltage after 7 hours = 4.06V
Drain: 0.05V in 7h
Even if this is not “super scientific measured” data, are my estimations (BELOW) correct about the potential draining from 4.20V to 2.80 (=1.4V) ?
I did a “Rule of 3” calculation.
In this light, a battery would be drained from 4.2V to 2.8V in around 11.6 days
[0.03V drained in 6h; so 1.4V would drain in 280h. 280h = 11.66 days]
In this light, a battery would be drained from 4.2V to 2.8V in around 37.9 days
[0.02V drained in 13h; so 1.4V would drain in 910h. 910h = 37.916 days]
On the Road M3 Pro
In this light, a battery would be drained from 4.2V to 2.8V in around 8.1 days
[0.05V drained in 7h; so 1.4V would drain in 196h. 196h = 8.16 days]
Why am I doing this?
To inform manufacturers about this type of drain in these e-switch lights, and to lead them to make this information public for customers.
I may, of course, have “faulty” flashlights and these may be abnormal drains, but I guess people should know about this when buying their lights.
Also, there is a great possibility to drain the batteries down to 0V, which is even worse than just draining to 2.8V…
So, help me on this “exercise” and share your data if you have them.
And please comment on how “good” or “bad” are these draining values.
Thanks in advance :+1:
