I have a small dive light that’s powered by 3 NiMH AAA’s. I used eneloop black to power it, but they don’t last overly long, and now they went Hi-Z so I can’t use them anymore (for this light).
The 3 AAA’s are in a little cyclindrical holder with minus at the bottom and a spring loaded plus button at the top. The holder is 58 to 60mm long and slides into a tube with an inner diameter of 23.8mm.
Instead of buying new eneloops I wonder if I shouldn’t better use a single Li-Ion cell of suitable dimensions.
Ideally, it should have 23mm diameter and a length of 60mm, including the top button (and a protection circuit, if available).
But I would gladly take the cell with the highest capacity even if it is slightly thinner and shorter.
I looked up lygte-info.dk’s Index of tested LiIon batteries and found protected 18500’s with 2000mAh nominal, tested in 2014 and 2019, from EnerPower and Keeppower.
Even 2019 is quite a while ago. And I know the guy behind this website stopped testing new cells already a couple years ago.
Do you know any newer cells that fit my requirement better? Which one would you recommend?
