Has anybody here swapped the LED of an Armytek Prime C2 V3 XP-L? I like this light quite a bit, but Armytek has made it really difficult to get the LEDs PCB out. It is fastened with brass rivets inside the head. The difficult part is that one needs to avoid damaging the cables because those can’t really be replaced. The problem with this is that the cables come up through the rivets!
An experienced modder is helping me and he has basically given up on the light. Too much risk, he says.
Being brass you can carefully upend both of the ends and presumably pull out the star. Precision work with a small diameter steel rod, or even dentist tools.
Assuming its not then glued you can remove it. If it is glued you may have to break it
If the rivets were not there would the reflector hold it in place (or you can add glue later as well).
You could pull it apart but ruin the light, or you may be ale to replace without a hitch or something in between, is it worth the risk?
Sorry mate, no experience. My prime A1 didn’t have the rivets. I would disconnect the leads first and try with a pick, sharpened small screwdriver, or knife to pry up the edges of the rivets. It doesn’t matter if they are destroyed if you have thermal epoxy or if the reflector/optic presses down on the star…
I don’t remember scraping any glue from the star or flashlight, so it must have been only thermal paste. I reflowed a warmer XM-L2 onto the stock star and replaced the paste with what I have.
No it’s not glued. AT only use sticky thermal paste. You can check it yourself, the MCPCB can slide sideways a bit. I will mod mine as well as soon as I got some left over 219C
AT use rivets to make it more durable (and harder for us). I love this Prime very much, slim and durable except the too stiff switch.
In the russian fonarevka forum somebody opened his Wizard (XM-L2). I think the PCB was just screwed down. It’s a little bit more difficult because the bezel ist press fit instead of screwed. You need to pry it up.
