I’m looking for a better head strap for H03,
Anyone knows an alternative to the Armytek’s headband with the plastic holder, supposed to be the best.
It’s about $5 not so bad but shipping is another $12.
This is the one I am using with the PL47, you might find it cheaper if you look in the Chinese sites like Aliexpress
I looked, can’t see a close match but thanks. will check it out.
Would a Nitecore HB02 headband work?
They're made very well, and they're pretty cheap.
My opinion of this headband is that it’s very uncomfortable, but I love the headlamp. I actually use the previous generation wizard v3 headband,which has a rubber plate. I used the plastic one on my mountaineering trips and hated it after an hour.
That plastic holder does look uncomfortable.
I would try to avoid that. ![]()
EDIT: I have the Imalent headband that AlexGT recommended.
It's nice and comfy.
Is it this one?
How would I secure the H03 in it?
Mine has more blue in it, but that's basically the one I was thinking of.
Apparently you don't.
Sorry.
Bad idea on my part.
ok no biggie.
Will this one be close enough?
H03 Body diameter 21.6mm ?
How about
Nur US$11.55, kaufen Sie den besten Skilhunt Verstellbare abnehmbare Taschenlampe Stirnband Online-Shop zum Großhandelspreis.
The plastic Armytek holder is great on an armytek light. I like it more then the armytek rubber holders for most things.
The plastic Armytek holder is not great for a Skilhunt H03. The flat spots on the H03 drag when you adjust light up and down. Not sure how much you adjust your light. It has kept me from using mine in the plastic AT holder.
I get some time I will do some more playing with some other headbands.
I use to have one of the Nitecore like above , and if I remember correctly the elastic rings float. You could use 2 one on each side of the head strap.
