Howdy!
I've been looking into aspheric lenses a little bit. My research didn't yield a whole lot of definite answers, but I've learned a bit looking through quite a few threads as well as manufacturer sites. Some of you will know most of this (or more). I'm writing it to save the less informed some research. Also note that this might seem like an advertisement for ThorLabs, but I don't know a whole lot about them besides their products look pretty nice and their website is informative so much of the information I've gleaned comes from there. If I have made a mistake, I will gladly fix it if one of you with more knowledge points it out to me. Don't be shy. I have thick skin.
I've run across two manufacturers that publish the specifications of their lenses. Their lenses are expensive(ish).
Thor Labs
http://www.thorlabs.com/navigation.cfm?guide_id=11
Edmund Optics
http://www.edmundoptics.com/optics/optical-lenses/aspheric-lenses/aspheric-condenser-lenses/2454
You will notice that both of those links go to "Aspheric Condenser Lens" pages. Those are the type of lens that we would use for focusing the light of an LED. The theory of the lens is that it takes the point source (really a plane source) and bends the light being emitted into nearly perfectly parallel beam. These lenses are flat on one side and curved on the other.
"Aspheric" simply means not spherical. These lenses have a profile that is roundish in appearance, but follows this equation (from ThorLabs site).
I've tried to figure this equation out and come up short. I'm guessing when I say that I believe z is the height of the dome, R is the radius (perpendicular to light path) and y is the direction parallel to the light path. All of the A's are constants.
Terminology:
Aspherical Condenser Lenses have two surfaces: The Plano(flat) surface and the Aspherical(curved) surface.
-The flat surface is mounted facing the LED die. The curved surface faces out.
Focal length (f): Distance from Back Principal Point(H) to the Focus Point.
This is the number that I was looking at when I was beginning to buy an aspheric for a project. It is NOT the number that we need to determine mounting height.
Back Focal Length (fb): Distance from the flat back plane to the focal point. This IS the number that we need to determine mounting height. It is always a smaller number than the Focal Length.
Edge Thickness(te): Edge thickness is useful for mounting purposes. It is merely the height of the cylindrical ring portion of the lens.
Center Thickness(tc): Center thickness is the height of the lens measured from the Back Plane to the top of the curvature.
Back Principal Point(H): This is the height in the lens that focus length is measured from. You can do math to find out where it is in the lens, but is not specified explicitly on data sheets. That is why we must use Back Focal Length for mounting purposes.
When focused, an aspheric lens will project a beam that closely resembles the geometry of the LED die. I hope ThorLabs doesn't mind me using their pictures, they are nice ones :) Notice the square in the center.
There are a couple of ways to get rid of the square hot spot. One is to mount the lens slightly longer or shorter than it's focal length. The other is to rough up the plano(flat) surface with really fine grit sandpaper. ThorLabs sells 600 and 1500 grit treated lenses as "diffuser lenses". I have one of these ordered and will report on it later. Here is their pic of the same setup with a diffuser lens.
This treatment does reduce light transmittance. I do not know how much. Rougher grit treatment reduces transmittance more than finer grit does.
The next big topic I encountered during my research is the great "Lumens vs. Lux Conumdrum".
Please forgive me if I have this wrong. From what I have read, it seems as though total lumen output will be markedly lower for an aspheric lens when compared to a reflector while the LUX will be markedly higher. Perhaps OL or DrJones will pipe in with more info and/or correct me, but my understanding is that the light emitted to the side is basically lost since the aspheric cannot focus it, thus the lower lumen output. At the same time, the light that is emitted forward directly into the lens is focused extremely tightly, thus the high LUX.
Waiven Collars (patented and trademarked) purportedly help recapture some of the lost lumens by redirecting some of the light lost from side emission. I'm not really convinced they do much, if anything.
Some have asked if a small reflector could be used in addition to the aspheric lens. I believe that OL has tried this and reports that horrible rings were present in the beam such that he determined it was not worth the effort.
Regarding lost lumens, I also believe that the thickness and optical purity of the lens plays a part. Highly transmissive flat lenses with optical coatings can get into the 98-99% light transmittance range. These lenses are comparatively thin though. I wonder what their transmittance would be if they were 10-20mm thick. I'll bet it would look more like an aspheric. Here is ThorLabs graph for a 10mm thick lens. It's right at 90% for the area we are interested in. I'm hoping their AR coating helps that a bit, but I can't find a Transmission graph for that, just one for reflectivity.
Anyway, some of the lost lumens may be to the thickness of aspheric lenses. Some of it may be due to the quality of the lenses such as those sourced from the Chinese sites. The balance is from the unfocused "side light" emitted from the LED.
I believe that some of these lost "side light" lumens can be recouped if we are willing to set the height of the lens lower than the back plane focus length. This will be at the expense of throw however. The beam will not be as tight. I, however don't need a light that will throw a mile or more. I want one that throws well. But some lesser distance will suit me fine. I plan on experimenting with this to see if there is a sweet spot where the lost lumens are minimized while keeping respectable throw.
That's all I can think of right now, but I feel like I'm missing quite a bit. Aside from their expense, these lenses really interest me for future builds. I think I'm going to try and build a zoomie MT-G2 and see how it does.
