It looks like mine is going to be stuck in Fontana for a longer time than I want to be stuck on the hostile surface of this earth.
December 11, 2021, 4:01 pm
Departed Shipping Partner Facility, USPS Awaiting Item
Fontana, CA 92337
Shipping Partner: AWESUNG
Your item departed a shipping partner facility at 4:01 pm on December 11, 2021 in FONTANA, CA 92337. This does not indicate receipt by the USPS or the actual mailing date.
December 11, 2021, 4:01 am
Arrived Shipping Partner Facility, USPS Awaiting Item
Fontana, CA 92337
December 10, 2021, 4:01 pm
Picked Up by Shipping Partner, USPS Awaiting Item
Fontana, CA 92337
But did you try it?
It works for dozens of people, myself included.
The wrap is flexible and it moves enough that it works.
I took the batteries out quite a few times and the wrap didn’t get damaged by unscrewing and screwing tight.
Checked again today. It does work with 2 and 3 batteries but not with 1, likely due to a contact in the limit of the batteries length.
This flashlight is optimized for high currents during turbo operation so a less than excellent contact is just not worth it. Thus I’m not going to put flat tops in it, particularly when the solution is so easy: I’ve put solder blobs on 3 of my flat tops, it’s really easy to do, which makes for excellent contacts. With the solder blobs it works with 1, 2 and 3 batteries without fail.
I suppose I really have poor soldering skills, or probably do not know how to properly solder, or do not have the right soldering lead or other things needed.
I’ve tried doing a solder blob (or what I think is a solder blob), but after removing / charging the battery a few times, the blob will fall off…
I probably did something wrong with my solder blobbing…
Don’t think you can do solid job with basic soldering iron.
But you don’t need creat a button top.
The difference between Samsung 40T (don’t make contact) and Molicel P42A (make contact) is pretty low.
Keep the surface of our cell clean and rather makes a small plain, not a hill.
Issu is the pressure the light create on our cell when you screw it.
So try to don’t make a high mount on our cell et don’t screw light too much necessary.
