Interesting, but that’s way more than I’m willing to pay for an 10180 light. The head looks a bit bigger than necessary…
It IS indeed a bit larger. and certainly pricey.
I just mentioned it as it is still a pretty neat light in the 10180 class !
Sure it is neat and I didn’t knew about it, so thanks for spreading the info. The moonlight mode is pretty handy
Does it have an electronic switch with standby drain?
I honestly do not know about the switch, GOOD QUESTION.
It is pretty soft to the touch so it very well could be electronic and have a bit a parasitic draw.
I wonder if I emailed the company if they would reply or even know the real answer.
Oh well, I try to get in touch with someone at MecArmy and see what they say.
In the mean time, maybe I’ll pull out the old Fluke meter and see what it says.
I received my jetbeam mini
it’s so tiny, I love it
it will be my necklace “gem” on my camino to Santiago de Compostela (leaving tomorrow)
AWESOME, I had a feeling you would like it !!
Have a safe and enjoyable trip.
Dave
Tried different lenses
http://forum.fonarevka.ru/album.php?albumid=891&pictureid=15599
http://forum.fonarevka.ru/album.php?albumid=891&pictureid=15597
http://forum.fonarevka.ru/album.php?albumid=891&pictureid=15596
http://forum.fonarevka.ru/album.php?albumid=891&pictureid=15598
Hi all,
I really like my M01 Nichia but I´d like to be able to attach it quickly to a metal surface… or ebene better, to any surface. Since it´s not tailstand capable the only option I see is to attach a string to it and hang it somewhere… but Id like to have a magnet on it … any ideas how to do that?
Thanks,
K.
Hi all,
Thanks,
K.
Take a look at this [BG] 10x5x5mm Ring magnet Don’t know the lanyard knob size on M01 but it might fit. If not - search for other ring/hole magnet and use some epoxy to affix it to the light. If you do not require a lanyard hole you can file it off altogether and use normal disc magnet - those are more easily found at exact size.
Thanks, will take some measures and see if it fits… Don´t want to saw off the whole lanyard hole thing, but I´ll try to fit a small round magnet inside the tailcap bottom and see if that does the job…
K.
