MSRP: $300 without extension tube, batteries, and carrier.
Asking: $129
Sale is as is!
Included Contents:
- Astrolux MF04S XHP70.2 Flashlight
- Short tube
- Extension long tube
- 2x battery carriers
- Battery carrier connection spacer
- 8x Samsung, INR18650 - 30Q batteries
- Shoulder carrying
- Lanyard
- Spare O-rings
- User manual
The Astrolux MF-04S is a high-output, long-range searchlight delivering up to 6,000 lumens and roughly 1,549 meters of throw using an XHP70.2 LED. When paired with an extension/long tube setup (similar to the BLF GT style extension concept allowing double the 18650 cells), capacity doubles to run on an expanded battery configuration.
Key Specifications & Performance:
- LED Type: Cree XHP70.2
- Max Output: ~6,000 lumens
- Battery: Powered by 4 flat-top 18650 cells via a carrier
- Dimensions: > Length of 235 mm > Head diameter of 136 mm > Body/tail diameter of 52 mm > Weight: Approx. 1,290 grams (empty) / 1,460 grams with batteries Operation & Features:
- User Interface: Uses a single side-switch configuration with standard mode steps or smooth ramping options, plus a hidden blinking group (Strobe, SOS, Beacon)
- Access Shortcuts: Double-click for Turbo, triple-click for tactical/blinky modes.
- Build: CNC-machined aluminum body with a durable anodized finish and integrated tripod mount threading.
