Dr Jones - thank you very much. I appreciate it.
The Maxflex driver is 0.90 inches which is very close to 22.5mm = 0.88 inches.
http://www.taskled.com/
Taskled drivers also have a good reputation at CPF.
Also there are drivers at LCK Ledstore” if you want to go cheaper.
Did you get the 21mm board yet? Did it fit or is it too loose?
Thanks for the info Cncyana, I’ve bookmarked these stores as I like the driver options they have. I’m going to take some of the previous advice on this thread and strip the old driver board of all it’s components except for the switch and use it as a contact board. I’ve got the latest dmobydrv driver from Dr Jones on order. I haven’t received the other contact boards yet. I’ll update the thread with the new build along with some pictures.
Can’t go wrong with Dr Jones boards!
When you modded your JM07 Pro:
1) Which Dr Jones board did you replace the original board with?
2) What diameter was the new board?
3) What diameter was the original board?
thanks
I’m using the Dr Jones guppydrv with the JM07 pro, as far as I’m aware all of Dr Jones’ drivers utilise the Nanjg drivers which are 17mm in Diameter. The original JM07 driver is also a 17mm Nanjg driver and connected to a 20mm contact board.
