Recently it’s come to my attention my JM07 side-clicky is lacking in wow factor at around 2.3A, so I really want to add some juice as it’s become a bit of a shelf queen, sitting in the shadow of the JM07 pro which I’ve recently modded with a 3.4A Dr Jones Driver. :bigsmile:
Review here:
Like the Pro version I figured it would make a terrific host, considering:
- good heft of aluminium
- aggressive cooling fins
- screws to secure the emitter
- emitter being attached directly to the host with no pill for excellent heat transfer.
My original plan would be to add another 3.4A DR Jones driver. Taking it apart was very easy, thanks to this:
This is a small vial of anti-adhesive that I purchased from an electronic store for around 50c. Both the Bezel and driver retaining ring were threaded and fixed, but almost fell out after carefully applying a thin layer of anti-adhesive to the edge of the threads:
Bezel removed with anti-adhesive
Here’s the driver spring and retaining ring:
Removed again with anti-adhesive
Straight out of the freezer and used a screwdriver to force out the emitter, the only part that required a bit of force and patience:
Fully dis-assembled:
And here’s the driver:
Here’s where I hit a brick wall. The driver diameter is about 22.5mm with no contact board. So I’m hoping to get some advice.
Anyone know of a contact board or suitable driver around 22-23mm in diameter? If I lose the side click functionality it’s not a big problem.
I have a 21mm contact board on the way from int outdoor, however it’s probably too small.
Otherwise, is there a mod I could do to the current driver? Like a resistor mod? I’ve never done one, so could really use some advise here from some of the experts. :~
