I’ve been looking for an automotive mt-g2 driver and have yet to find anything, so I’ve decided to ask the brilliant minds here to design one for me.
Here’s what I want:
-input voltage of 10-40 volts. It would be great if it could work on both 12 and 24 volt systems, but this isn’t critical
–6 volts out at 3-5 amps would be great. It would be even better if this was adjustable. 7135 stacking would even be ok
-multiple channels out would be a major plus
-able to use an external PWM signal for dimming, strobe, etc
-Efficient. I’ve driven an mtg2 with a linear regulator, but it burns more power as heat than the led gets
-budget!
-open source design that can be used by anyone, personal or commercial
If someone can come up with a driver that suits my needs I’m willing to put a $100 bounty for whoever can make it. I’m also willing to give a way a few 502b hosts for links/ comments I find useful.
I have done several trunk/dome light installs using the cheap LM2596 boards with the equally cheap '10W' 3x3 LED arrays. No extra components, just the original power/ground wiring feeding the board, and all are still working great. If you need a remote dimmer, the onboard pot can be removed and replaced with an offboard pot. There's also a blank spot on the board (right beside the pot) for a 0805 limiting resistor, to set the max voltage available from the main adjuster.
If I’m not mistaken, the 3421 and 3423 can only provide one amp. I think for now I’ll try a buck supply like drivex suggested with 7135s to limit current until someone can help me design a new driver
If you intend to do current limiting, my opinion is that while adding 7135s after a voltage-controlled buck circuit will work, it’s a big waste of energy and effort.
Buck regulators can either be voltage or current controlled. You should simply get a current controlled one instead. Here is an 10A example.Here is a cheaper, lower powered one at 4.5A. Bear in mind that you don’t want to be pushing the envelope with these, they probably generate a lot of heat when you run them at the highest current they support.
Oops, my mistake! I overlooked that the existing buck suggestion was already CC/CV. Any of those 3 should be capable of driving an MT-G2 at a set current.
If you buy the one I suggested, you can connect the leds directly to it. One trimmer is for voltage limit and the other is for current. You can find out which is the voltage one by running it without a load and trying which trimmer can adjust the output voltage. If you want to use it as a constant current driver, set the voltage to maximum and current trimmer to minimum. Then connect it to the led(s) with amp meter in circuit and adjust the current with the current trimmer.
This goes for any CC/CV driver you purchase. When dealing with the ultra-cheap and badly labeled products, keep an eye out for the number of pots/trimmers onboard: if it doesn’t have at least 2 then it’s probably a constant voltage setup.
Sure. Also if you want to connect more MT-Gs to one driver, wire it in parallel. After setting the current make sure to set the voltage trimmer as low as possible not to limit the current but close to it. Do it just to make sure that if any of those leds fails, the driver won’t damage other leds.
For example - You will connect three leds to it and set the current to 9 A (3 A for each one) if one of the leds failed and the voltage trimmer was set to max, the driver would increase the voltage as high as possible to force 9 A current through those 2 working leds. If you set the maximum output voltage to lets say 7 V, there is almost no chance of damaging the other leds. Is that clear?
(You may also ask why in parallel if you want to use just two MT-Gs? Because the driver needs some voltage reserve for its function and two MT-G leds need whole 12 V)
If you’re looking for a high current cc driver designed to survive the high voltage spikes from an alternator, there seems to be only one available at this time. Check the link in my first post for “DIWdiver” in my light bar build thread. Contact him directly through the other forum and you’ll receive an extremely detailed response. One or more of these drivers should easily suit your needs, and with the added benefit of thermal management for the emitters & driver plus over voltage protection.
You could also use a boost driver in that situation. I don’t know but I assume that with a maximum of 60v on the input that this sort of driver would also be happy to handle any spikes the alternator might throw out. EDIT: (you might want to purchase from a different seller though. The one I linked has <97% positive feedback. There are many sellers to choose from for a similar 600W boost unit)
ehhh… high efficiency boost circuits are possible. I’m not sure that the ones I linked are the greatest, but bucking down from 12-14v to 7v is definitely not going to get you into the best range for a buck driver. The higher the output current, the worse it gets - putting a bunch of MT-G2 LEDs in parallel is going to add up.
Compare the data posted on the TaskLED website to get an idea of what I’m talking about. Come to think of it, why haven’t I brought up TaskLED as an option?! Seems like I always do.
The HyperBoost can do 3.2A and 80v. TaskLED says it’s tested through 130W, so 3.2A @ 40v. In an automotive application you’re looking at 85-91% efficiency for this driver when driving between 5 and 1 MT-G2s.
The H6CC can do 6.7A at <Vin. This one takes a little more interpretation due to the presentation of the data, but I’d say we’re looking at ~88% efficiency when driving a pair of MT-G2 in parallel at 6.7A total or maybe 91% efficiency when driving a single MT-G2 at 3A.
Really in any application you want Vin to be relatively close to Vout, but it’s not always practical and you must balance that with keeping current under control… the higher the current the more the losses….
The TaskLED drivers are a little pricier, but they both look like decent options for this project, depending.
I have not found any indication the generic Chinese LM2596 boards aren't completely happy in an automotive environment. I've seen just about every obscure, bizarre failure that can happen to a car and from my experience these oft-mentioned dangerous voltage spikes should cause about as much concern as an attack by a rabid unicorn or a cosmic ray strike.
