I’ve heard about the electronic gizmos that don’t work, the cathodic protection that is for in water usage, and of course the messy oil sprays, and i remember reading that positive ground causes rust to occur more rapidly, could a constant small load negative ground prevent rust?
Any other rust prevention ideas are greatly appreciated
its for a car, i wondered if a small continuous load has ever been shown to reduce oxidation of iron, a few eneloops charged once a week would be a simple modification
also you never know what new ideas have been invented but are not yet well known, someone on BLF had mentioned a product called evaporust a while back that my google-fu never uncovered
Cathodic rust protection like ocean going ships use is cheap to make.
Existing “clean” metal is a must for application site.
A sacrificial anode made of zinc is charged with super-low amperage High PWM dc current.
No longer available at JC Whitney, it was comprised of zinc tabs screwed to rust areas and connected to the module.
I had thought you could take nickles or pennies and burn off the copper coating with Hydrochloric [Muriatic] acid and use as an anode.
A 555 type timer circuit banging out DC high voltages at sub-amp levels should work fine.
Please note several snake-oil salesmen ruined the reputation of this proven technology.
These cheap-o units usually had a 9v battery or/or no high frequency output circuits.
