WUBEN A1
Save $139 with code (message me)
20000LM High Power Output Portable Flashlight 2000M Long Shoot 33600mAh Large Capacity LED Torch Spotlight With 4*SBT90 Remote Switch Powered By 8*21700 Battery
Features:
-Using 19 CREEXP-LHDLEDs, it achieves a strong brightness output of 20,000 lumens, a light intensity of 22,200 candela, and a range of 290 meters.
-Lightweight and sturdy cylinder body manufactured by one-piece CNC technology, with excellent heat dissipation performance.
-Built-in two 21700 rechargeable lithium batteries (total 9600mAh), with built-in intelligent lithium battery charging circuit (USB/TYPE-C interface).
-The tail parallel tactical switch designed for tactical applications can be flexibly controlled by both hands.
- With a flash function (STROBEREADYTN utility model patent) and a key
Strong light suppression function (TurboReady).
- The special function of random variable frequency flashing, the flashing frequency changes with the orange, effectively enhancing the instant dizziness
Effect.
-High-efficiency constant current circuit, constant brightness, 13 hours of long-lasting battery life.
-Built-in temperature control module.
-Double-sided coating scratch-resistant optical lens.
-Made of aviation-grade aluminum alloy, three-level hardened surface treatment, in line with |P68 protection standard (2 meters underwater), anti-drop height of 1 meter, and tailstand function.
