Basen 18350 800mah 12A button top
I’ve seen a review for the 700mah 10A version of these and they tested well with capacities near 900mah. Figured I would give these 800mah ones a try. I don’t have professional testing equipment so I used my Lii 500 nor test (discharge rate was 250ma, charge rate was 300ma). Unfortunately I am unable to test these at higher rates so I have no idea if the claim of 12A is anything close to true.
Battery 1 discharge capacity= 699mah
Battery 2 discharge capacity= 713mah
Doesn’t seem as good as the older 700mah version, unless we are sacrificing capacity for higher amps.
If someone with actual testing equipment has a burning need to test these at higher discharge current I can give them away. Given the small capacity of 18350 cells I don’t see the point in using any of my light’s short tubes. Better off using larger cells for more run time.
