Both —- The lights I plan on using I leave cells in fully charged ( I usually unscrew the tail cap a little )— The cells might degrade a little, but what good is a light without a cell
Cells that I have as extras, I store in cases at 3.83V —- They’ll hold their capacity a lot longer
You can store your cells in your lights. Lights with a mechanical clicky switch do not have any parasitic drain, but lights with E-switches, and especially those with aux LEDs, do. The rate of drain is dependent on the light, but it can be very low, taking years to drain a full cell. Some lights with aux LEDs can drain a cell rather quickly, in a matter of weeks. To know for certain you’d need to measure the current draw if the aux LEDs are to be left on continuously. (see this thread) If it draws 200uA, this would use 1mA every 5 hours, which is >1 year to drain an 18650 with 2,000mAh left in it. If it has an e-switch but no aux LEDs, it could draw ~50uA or less, taking several years to drain the cell.
FWIW, I store mine in a plastic case fully charged. Have a pair from a decade ago that I use maybe once a year. Last I checked they appear to work pretty much as well as they ever did. Have a few more from around that time and they are as bad as they were then. If I had a much larger collection I probably would store them at a lower voltage. Have yet to degrade a decent cell so I just don’t see the need or point to not having a fully charged cell ready to swap as needed.
Every light has a cell in it. Even my e switch lights get the battery swapped / checked at least once a quarter. Has not been a problem for me. Never have a cell drop below 3 V in normal use. Just swap with a fully charged cell from the case whenever and don’t worry about it.
Just happened to check my backup 21700 yesterday. It is sitting at 4.13 V about 6 - 8 weeks off the charger. (4.15 V at about 24 hrs IIRC.) Only have 2 21700 so far. EDC one and when it gets down around 3.5 it goes on the charger and the one from the case goes in the light.
My most used light is an AAA and I have a special set of 4 AAA just for that light. Three of them are always fully charged and one is in the light. Have replaced the entire set a couple of times over the years as once the IR starts going up they just are no longer up to the task and get relegated to other uses.
I wouldn’t use the cardboard tab to prevent battery contact. That just makes the light more difficult to use. I’d just unscrew the tail cap a bit to accomplish the same thing if the light is going to be stored for a while.
It came with the light when I first purchase it. I just figure it will be perfect when the light is not in use. It’s so easy to remove the tailcap and remove the tab. I’m not sure what the tab is called but if the manufacturer uses it to stop the battery ground from contacting the spring then it has to be good for storing the light.
Does not matter really where you store it, as long it is not very hot, not freezing, and they are not under load. If you store it in a device with e switch, just unscrew the cap, so it wont discharge it too low. or remove them if it is not possible to open the circuit
All new cells I get, I run ’em through a cap test to see how they rate vs what’s on the tin. Then I leave ’em (ie, 4.2V) and store ’em in those plastic cases.
Lights which are in active use, ie, my “nightstand lights”, they’re in the lights and connected.
Those that I rotate through, I might have a cell in ’em, but they’re physically locked out. As in clicky off, unscrewed, optionally an insulating disc just in case.
I had one a pair of ’123s go China Syndrome in my MH20. Melted the shrinkwrap and everything was HOT.
Also had an 14500 similarly start fizzing in my GTmicro.
So figure even cells that were NOT abused nor run down (both lights were in active rotation and probably at least half-charged) could still have catastrophic failure and I’d have a pipeboemb go off right next to me.
So best to have the cells stored separately.
Mine are in those plastic snap-type cases but also in padded camera-cases to hold the stacks of plastic cases.
Wanna be thorough, stick ’em in vented ammo cases or the like.
