From the Xtar site:
[Compatible with CR123A/ Protected 16340]
You definitely want " protected" IF you get a 16340. Rechargeable is not absolutely necessary.
Unprotected has a fair likelihood of being over discharged and damaged in an application like this.
(FWIW, protected will also simply ‘go out’ suddenly when it hits cut-off. This could be an issue for some uses if the beacon location is a critical necessity, maybe even for finding it at the end of a dive.) Non-rechargeable will get weaker giving some notice. It does seem to have a low power reminder function, a good feature.
I do have a super powerful white strobe, but the Xtar can also be used as a non strobe beacon (easy for people to find me) as an instructor, so it will run all the time.
I do need rechargeable.
NITECORE NL169R - where is the best place to buy these please?
If it’s gotta be Amazon or Ali you have few options. NITECORE NL169R
Personally I wouldn’t buy a small cell that is USB charged. Some of the capacity is displaced by the electrics.
The rest of Amazon in that size is ‘unknown’ brands and probably shouldn’t be trusted.
Aliexpress - seems ALL of them are unknown and rampant with bogus claims for capacity. If you buy there you are pretty much on your own.
Seems like your location creates problems for lithium access?
There are numerous choices like LION Wholesale for the US.
Most of this group shops sites like this, unless they are taking a wild ass guess/hope on Ali.
