ChatGPT
here:
14500 Battery: 1100 mAh
18650 Battery: 3500 mAh
21700 Battery: 5500 mAh
We will assume a nominal voltage of 3.7V for all batteries.
Energy Capacity Calculation
Energy capacity (Wh) is calculated as follows:
Energy Capacity (Wh)=Capacity (Ah)×Voltage (V)Energy Capacity (Wh)=Capacity (Ah)×Voltage (V)
14500 Battery:
Capacity (Ah)=1100 mAh1000=1.1 AhCapacity (Ah)=10001100mAh=1.1Ah
Energy Capacity=1.1 Ah×3.7 V=4.07 WhEnergy Capacity=1.1Ah×3.7V=4.07Wh
18650 Battery:
Capacity (Ah)=3500 mAh1000=3.5 AhCapacity (Ah)=10003500mAh=3.5Ah
Energy Capacity=3.5 Ah×3.7 V=12.95 WhEnergy Capacity=3.5Ah×3.7V=12.95Wh
21700 Battery:
Capacity (Ah)=5500 mAh1000=5.5 AhCapacity (Ah)=10005500mAh=5.5Ah
Energy Capacity=5.5 Ah×3.7 V=20.35 WhEnergy Capacity=5.5Ah×3.7V=20.35Wh
Volume Calculation
Using the same volumes as before:
14500 Battery:
Volume: ≈7.7 cm3≈7.7cm3
18650 Battery:
Volume: ≈33.18 cm3≈33.18cm3
21700 Battery:
Volume: ≈48.5 cm3≈48.5cm3
Weight Calculation
Using the same weights as before:
14500 Battery:
Weight: 20 grams20grams
18650 Battery:
Weight: 45 grams45grams
21700 Battery:
Weight: 70 grams70grams
Energy Density Calculation
Energy Density by Volume
14500 Battery:
Energy Density (by volume)=4.07 Wh7.7 cm3≈0.529 Wh/cm3Energy Density (by volume)=7.7cm34.07Wh≈0.529Wh/cm3
18650 Battery:
Energy Density (by volume)=12.95 Wh33.18 cm3≈0.390 Wh/cm3Energy Density (by volume)=33.18cm312.95Wh≈0.390Wh/cm3
21700 Battery:
Energy Density (by volume)=20.35 Wh48.5 cm3≈0.42 Wh/cm3Energy Density (by volume)=48.5cm320.35Wh≈0.42Wh/cm3
Energy Density by Weight
14500 Battery:
Energy Density (by weight)=4.07 Wh20 grams≈0.204 Wh/gramEnergy Density (by weight)=20grams4.07Wh≈0.204Wh/gram
18650 Battery:
Energy Density (by weight)=12.95 Wh45 grams≈0.288 Wh/gramEnergy Density (by weight)=45grams12.95Wh≈0.288Wh/gram
21700 Battery:
Energy Density (by weight)=20.35 Wh70 grams≈0.291 Wh/gramEnergy Density (by weight)=70grams20.35Wh≈0.291Wh/gram
Summary Comparison
14500 Battery
Volume: 7.7 cm³
Weight: 20 grams
Energy Capacity: 4.07 Wh
Energy Density:
By Volume: 0.529 Wh/cm³
By Weight: 0.204 Wh/gram
18650 Battery
Volume: 33.18 cm³
Weight: 45 grams
Energy Capacity: 12.95 Wh
Energy Density:
By Volume: 0.390 Wh/cm³
By Weight: 0.288 Wh/gram
21700 Battery
Volume: 48.5 cm³
Weight: 70 grams
Energy Capacity: 20.35 Wh
Energy Density:
By Volume: 0.42 Wh/cm³
By Weight: 0.291 Wh/gram
Recommendations for Headlamp Use
14500 Battery
Pros: Very lightweight and compact.
Cons: Lower energy capacity, lower energy density by weight.
Suitability: Suitable for low-power headlamps where compact size and low weight are crucial. Limited runtime due to lower capacity.
18650 Battery
Pros: Balanced size and weight with high energy capacity. Highest energy density by weight among the three.
Cons: Heavier and larger than the 14500 battery but still manageable for most headlamps.
Suitability: Ideal for high-power headlamps requiring longer runtime without adding too much weight. Most commonly used and widely available.
21700 Battery
Pros: Highest energy capacity, good for very high-power applications. Highest energy density by volume.
Cons: Heavier and larger, which might be less comfortable for headlamp use.
Suitability: Suitable for very high-power headlamps where maximum runtime is required, and the extra weight and size can be managed. Less common in headlamp applications due to bulk.
Conclusion
For lightweight and compact headlamps: The 14500 battery is a good choice if minimal weight and size are paramount and lower energy capacity is acceptable.
For balanced performance and longer runtime: The 18650 battery remains the best overall choice due to its superior energy density by weight, making it suitable for most high-power headlamps.
For maximum runtime and high power: The 21700 battery is suitable but may be too heavy and bulky for some headlamp users, making it less common for this application.
The 18650 battery is generally the best recommendation for headlamps, providing a good balance of weight, size, and energy capacity.
