If I had a bunch of 18650 batterys and wired them 3 in series and several ( don’t know what it would take) in perellel, could I charge them with a 12 volt automotive charger on the 2 amp setting. I know probably not but just qurious
Lithium Ion batteries require a very specific charging algorithm. They are very intolerant of inappropriate charge or discharge. With NiMh or NiCd, these
batteries can be safely charged with ‘dumb chargers’. Try that with a Li-Ion, and your house may burn down! Buy a quality charger such as a Xtar
VP1, VP2 or VP4. These can be run off 12 volts, and will properly (and safely) recharge you Li-Ion cells.
What if there was a small charging circuit between the auto charger and the battery pack Beachlogger suggested? Is the auto battery charger just too wrong for this, or is there any way it could be made to work? You can buy CC/CV circuit boards on eBay for a few bucks. You just need input voltage, then you adjust a couple setting screws to get the charge voltage, charge current, and CC current.
Could? Sure, if you want to screw around with it enough you can do all kinds of things to ‘force’ it to work.
OTOH - If you have to ask you sure don’t want to be the one doing it.
Real answer - NO! Automotive chargers are electrically very ‘dirty’ and not suited to being a power source for lithium chargers.
Seems you really don’t know what you are doing unless you know you need/should put a balancing circuit or PCB protection circuit on this pack, and know how to do it. If you don’t, the price of a hobby charger is the lesser of your issues.
Doesn’t matter, principal is the same, potential problems are the same, just not quite as likely.
For lithium it’s pragmatic to have protection, unless it is SINGLE CELL….AND YOU KNOW WHAT YOU ARE DOING.
Once you put a PACK together, the potential for getting out of balance with unequal charging and potential unwanted results becomes VERY possible.
Just out of quriousity, what if all the cells were charged singulary in an i4 , then put in a series perellel and discharged say in a cordless tool, are there safety issues then?
Technically, yes. You have no way of monitoring them. With the i4 you have no good way to match the cells. One or more of them will be a ‘weak link’ and possibly get over discharged, which will damage them. This starts up a cycle of further imbalance, more damage……etc. This can lead to problems you would rather not have.
In addition most commercial packs (so you don’t have to solder) won’t fit, or are of such poor quality they cannot deal with the amp load. The packs should be soldered (properly) together.
People want to dump the obnoxious NiXX power packs all the time and replace them with Li-on. You can certainly do it. I’ve got a friend right now that is doing it for a tiny chainsaw he has that has no more charger (2xdead), one dead pack, and a lame one. This guy is a very bright engineer and I’ve spent probably 10 hours bringing him up to speed on how to do this without burning the house down. It turns out he could have bought a Li-on powered chainsaw of similar size for less than he’s spent on materials alone.
Cheap out on lights, they don’t burn your house down.
Do not cheap out on batteries and chargers…they can. People seem to get confused about this part.
