Best bycicle flashlight? (Cheap)
Hi, I am looking to buy a good cheap bycicle flashlight to use for riding my bike in unlit area. Ideally, the flashlight should be cheap, and either attach to a road or mountain bike. My requirements are a long runtime (sustainable ) combined with good brightness.
I was considering buying a bracket from china to attach a standard flashlight to the handlebars, it may be an option to consider with my existing flashlight.0.46€ 93% OFF|Fahrrad Licht halterung Fahrrad Lampen fassung LED Taschenlampe Scheinwerfer Pumpst änder Schnell spanner Grad drehbar| | - AliExpress.
I do feel like this may break off from the jolts of riding and I destroy whatever flashlight I put in.
If we have any biciclists here on BLF, please give me any recommendations would be appreciated.
AliExpress had a sale of Lumintop B01 for $16. If you keep looking, you may still find it at this price
ASTROLUX Bicycle lights.
Pro:
  • Inexpensive
  • Decent build quality with aluminium shell.
  • ~4800mAh true capacity (for the models that I have tested)
  • Comes with solid quick release mounts.
I have Astrolux® SL01 on my bike, I use it every week for over a year now. No issue or whatsoever.
I believe it is made by Gaciron.
Thats a nice one.
I have and recommend the Fenix ALB-10, ALB-10
I’m not sure where you are located, but if you search you can probably find it for less than this amazon listing.
ALB-10 is just a mount.
My take - Offbondage. Crazy name but it’s a cheap and fairly bright light with decent size battery, not only tat it also has anti-glare optics with a cutoff line so you can use it in the city and you won;t blind other people.
https://aliexpress.com/item/1005005117980467.html
I bought one of those holders that you show but never use it because there is a simpler version of the 18650 flashlight holder. They used to be available from China for just a buck but now if you live in the US it makes much more sense to buy from a US seller on eBay. I’ve used the combination of the “360 degree flashlight holder”, a quality NCR/Panasonic 3,400 mAh 18650 battery, and an XML-T6 LED flashlight for my bike lights. Output is about 900 lumens. The flashlight is focusable so you can set your beam to the desired width. The holder allows you to aim the beam exactly where you want it to go. The holder was designed specifically for this type of flashlight so it never comes loose but is easily clipped in and out.
Lots of sources for the flashlight like this one for $9 on eBay Adjustable Focus Zoom Cree Xml-t6 Led 1200lm Waterproof Flashlight Torch 3-modes | eBay
flashlight holder $6 360 Degree Bike LED Flashlight Mount Holder Lamp Stand Bicycle Torch Clip Clamp | eBay If you buy more than one from other sellers, the unit price goes down a lot (3 for $9.49) 360 ° Degree Universal Flashlight Clamp Bike Rotating Flashlight Holder Bracket | eBay
You can use any 18650 battery but the name brands like NCR or Samsung last a lot longer than the cheaper Chinese made batteries.
Here is the flashlight mounted on a trike but it works the same on my mountain bike handlebars https://i.postimg.cc/59LT752W/flashlight-mounted-on-trike.png
Theyre all good and cheap suggestions so far but I think the offbondage brand one seems legit, and 1000 lm for $16 seems like a good little torch
1000mAh is like 18350. :sweat_smile:
I just checked ali express and B01 cheapest is around $45. It looks like a convoy C8 size host with a different reflector which I guess gives a square beam.
That’s exactly what it is and there’s nothing wrong with that.
I think its designed for anti glare for oncoming traffic
Correct. So is the Offbondage I linked before as well.
That’s correct, the Fenix mount is by far a superior mount than what was originally posted.
